august 06, 2026, 06:31:43 am *
Skrevet av Emne: S: Ny Vintage speed VW Split BUS 42mm Header & Hidden Tail Pipe SuperFlow 2.3  (Lest 864 ganger)
thomas lybbe
« på: august 10, 2013, 05:46:38 am »
VW Split BUS Exhaust systems    VW Equal Length Header Exhaust Systems For 1960~1967 BUS . 42mm Header & Hidden Tail Pipe SuperFlow 2.3 Muffler Lowered BUS Features:1. TRUE equal length header, completed by CAD design and lots of dyno hours2. Fully TIG welded, all flanges, no gas leaking.3. #304 stainless steel muffler with #304 polished tail pips4. #304 Stainless steel Header and Flanges5. Fit stroker Engine with stock Rod, or 2mm(or less) under cylinder.6. 8mm stainless steel Type 4 muffler Flanges can be match ported7. Easy to adjust valves8. Build in M18 nuts, for tuning when use O2 sensor9. Pre 1960 BUS may need to modify rear apron or headers( 2 flanges include in this option).10. Clear oil sump, like Gene Berg oil sump1.5q & 3.5q, Bugpack sump, CB, Empi.pris 4500dkr plus fragt
thomas lybbe
« Svar #1 på: august 19, 2013, 15:05:38 pm »
Stadigvæk til salg
