august 04, 2026, 12:06:55 pm *
Skrevet av Emne: A-frame tauing I norge  (Lest 4648 ganger)
sammyboy
Bosted: trondheim
« på: oktober 04, 2013, 10:54:14 am »
Hei
Does anyone know if its legal to use a A shaped towing frame in Norway?
If so where can I buy one from?
Thanks
Sam
« Svar #1 på: oktober 04, 2013, 12:09:29 pm »
I would contact the "DMV" (Biltilsynet) and ask them.
Telefon: 02030
vegvesen.no
JarleA
« Svar #2 på: oktober 04, 2013, 13:17:49 pm »
Har sett sånne på både engelske og amerikanske forum. Lurer på hvordan sånne er å kjøre med. Hvordan blir det med sving og sånt?
« Svar #3 på: oktober 04, 2013, 13:34:37 pm »
I believe it's not legal.
sammyboy
Bosted: trondheim
« Svar #4 på: oktober 04, 2013, 14:30:13 pm »
Thanks for the replies.
All I could find on the net was that its legal in sweden.
I've seen campers towing small cars with them.
Shame if not legal.
« Svar #5 på: oktober 05, 2013, 00:12:34 am »
A tow bar works in Norway in the same great way as it works in any other country... I have used it a lot.
But - legally you are only allowed to tow a trailer of 350kg if it has no active brakes.
So - yes it works, but it is not legal.
« Svar #6 på: oktober 05, 2013, 00:38:23 am »
Are you allowed to tow a trailer at all that´s not registered as one?
« Svar #7 på: oktober 05, 2013, 00:58:46 am »
can it be called a trailer at all?
will be the same as for these:
http://www.the.no/images/bannernyhetsbrev_uke14_2013.jpg
or is it a trailer as long as there is no-one inside the towed car?
but have not seen these for sale in norway, guess you need to import one, or make one
« Svar #8 på: oktober 05, 2013, 01:04:39 am »
I think you will run into problems related to the weight of a towed car and the fact that it will have no brakes. Normally a trailer intended for a car require brakes, while smaller trailers (I think it is up to 350 kg) does not require brakes.
« Svar #9 på: oktober 05, 2013, 12:14:28 pm »
I stedet for å synse så finner man svaret her:
http://www.lovdata.no/for/sf/sd/td-19900125-0092-004.html
A.Hole
« Svar #10 på: oktober 05, 2013, 13:32:11 pm »
Så vidt jeg kan se er det egne regler for tauing. En bil blir m.a.o ikke en tilhenger selv om det er stag i mellom.
Men kravet til bremser er der.
Dvs du kan kun taue med stag i Norge dersom du har
 1: forsvarlige bremser på bilen som blir tauet,
 2: en tauepartner som aktiverer bremsene i bilen som blir tauet.
 Men som vanlig, sikkert lover med rom for tolkninger....
« Svar #11 på: oktober 05, 2013, 14:32:11 pm »
Bilen som taues skal også ha skilt, vanlige skilter eller prøveskilter. Dette er pga personskadeforsikring.
