august 05, 2026, 12:27:10 pm *
Skrevet av Emne: må slettes  (Lest 6617 ganger)
thomas lybbe
« på: oktober 29, 2008, 11:12:45 am »
A1 side winder exhaust system 1 5/8 ceramic coated. (not for use with heaters)fit for cross member bay widow bus, J-tubes(flanged)
Black dual port cylinder tin, dog house fan shroud, dog house oil cooler, backing plate, rear tin, 2pc.rr.cool tins, alternator, welded and balanced cooling fan, fan hardware kit, chrome upper pulley, with black CE insert and CE nut, black CE aluminum lower pulley and nut, fan belt, aluminum oil filler neck, billet oil filter cap, billet fuel pump block off, alternator stand, strap, and  breast plate.
Pertronix billet distributor with electronic ignition, billet dist. clamp, pertronix plug wires, NGK spark plugs, cap, rotor, oil pressure switch.
Dual 48 Weber IDA carburetors 3 hole with jay cee stacks,  Gene berg linkage,
Heavy duty CB aluminum raised roof engine case, full flowed, shuffle pinned center mains, added material behind ¾ cylinders, 8mm case savers.
84mm forged 8 dowel counter weighted crankshaft (std/std) vw journals.
Hardware kit complete-bolts, nuts, chromoly  head studs, high pressure oil relief valves.
Scat H-beam connecting rods 5.7  with ARP bolts, vw journals.
Camshaft and lifter set VZ 25
Scat Steel Straight cut cam gear set.
Main, rod, and cam bearings.
Light weight forged 8 dowel flywheel, chromoly gland nut and washer.
Gasket kit with rear main seal.
Oil pump-Melling high volume, with full flow cover.
94mm forged pistons and liners Mahle, with Teflon buttons.
CB ultra mag plus 42x37mm 94 bore with IDA ultra mag plus Port big beef manifolds pr.
9.0 compression
Cool tins
Aluminum  pushrod tubes.
Billet oil plate and deep sump kit.
Manton Chromoly  pushrods.
Scat 1.1 Ratio rocker arms
Aluminum bolt on valve covers
Stage 2 Kennedy pressure plate
Fully balance
pris 65nkr
foto kommer senere ..
« Siste redigering: november 12, 2009, 14:07:04 pm av thomas lybbe » Loggført
thomas lybbe
« Svar #1 på: oktober 30, 2008, 17:55:11 pm »
boing
thomas lybbe
« Svar #2 på: november 04, 2008, 21:38:33 pm »
ingen interesseret
thomas lybbe
« Svar #3 på: november 09, 2008, 22:43:58 pm »
boing
cato®
Bosted: Oslo/Mjøndalen
« Svar #4 på: november 09, 2008, 23:19:25 pm »
Når da ?
thomas lybbe
« Svar #5 på: desember 01, 2008, 18:53:45 pm »
tjek my blog for pic
http://vwvintagerides.blogspot.com/
« Svar #6 på: desember 05, 2008, 20:31:35 pm »
Her er noen sweet bilder
* 100_1454.jpg (132.72 KB, 820x615 - vist 667 ganger.)
* 100_1456.jpg (111.43 KB, 820x615 - vist 462 ganger.)
* 100_1459.jpg (106.5 KB, 820x615 - vist 556 ganger.)
ole boban
Bosted: porsgrunn men tidligere langesund
Boden Kratzende Autos
« Svar #7 på: desember 05, 2008, 21:53:16 pm »
jeg vet ikke hva som skjer i buksa mi nå jeg altså
thomas lybbe
« Svar #8 på: desember 07, 2008, 13:11:56 pm »
evt seriøst bud
thomas lybbe
« Svar #9 på: desember 11, 2008, 15:56:16 pm »
tjek blog for video Glad)))
thomas lybbe
« Svar #10 på: desember 16, 2008, 15:59:16 pm »
boing
thomas lybbe
« Svar #11 på: januar 12, 2009, 23:53:56 pm »
slet ingen interesseret
Hans
« Svar #12 på: januar 13, 2009, 09:59:32 am »
dårlige tider i folks lommebøker Glad    (dessverre)
o 1958/64 T1 Ragtop
o 1957 T1
o 1989 T3
thomas lybbe
« Svar #13 på: januar 13, 2009, 16:39:19 pm »
i no men det er en go deal
thomas lybbe
« Svar #14 på: januar 26, 2009, 18:23:22 pm »
ny pris 49000dkr
« Siste redigering: februar 18, 2009, 10:38:27 am av thomas lybbe » Loggført
« Svar #15 på: januar 26, 2009, 22:09:31 pm »
Hvem har bygd denne?
thomas lybbe
« Svar #16 på: januar 27, 2009, 00:22:06 am »
powerhouse usa
(john the owner of the shop)
« Svar #17 på: januar 27, 2009, 01:04:43 am »
Pris ferdig levert Norge?
thomas lybbe
« Svar #18 på: januar 28, 2009, 00:20:13 am »
47000dkr leveret til din adresse
thomas lybbe
« Svar #19 på: februar 18, 2009, 10:38:46 am »
stadigvæk til salg
« Svar #20 på: november 12, 2009, 13:28:12 pm »
se pm / mail.
thomas lybbe
« Svar #21 på: november 12, 2009, 13:40:15 pm »
den er solgt for LAAAAAAAAAAAAAANG tid siden Glad))  men den anden jeg har er faktisk mere seriøs ang hk og nm
mvh thomas
