august 08, 2026, 08:55:52 am *
Skrevet av Emne: S:2840ccm type 4/porsche 914 motor med 48/38 ventiler og 48idaér  (Lest 3109 ganger)
thomas lybbe
« på: august 30, 2009, 15:32:14 pm »
sælges som samlesæt(adskilt) da den en top skal svejses da der er en revne fra tændrør og mod ventil
har et par stykker der er interesseret men det er først til mølle eller man kan ligge et depositum
motor info
48 IDA weber carbs (not IDF's.. IDA's are what you want)
Fast Freddies pro linkage
K&N filters
.009 distributor (with compufire ignition)
New plug wires
Holley electric fuel pump (w/regulator)
Scat Billet crank (82mm w/chevy journals)VOLKSTROKER 4340 CHROMOLYBILLET
Crank case breather boxes (included)
Pauter rods (4340 CHROMOLY BILLET & 2000 12-POINT BOLTS)
Scat Lifters (Precision radius ground on face to insure long life under increased valve tension, lift and RPM loads)
Aluminum TYPE IV Valve Covers (Completely finned for high heat dissipation)
New fly wheel
J&E 105mm pistons (Forged Aluminum & Cast Ductile Iron Cylinders)
Babe Erson cam (custom grind)
Manley Stanless steel Valves (48 mm intake/38 exhaust)
Elephant feet (valve adjustments)
New rockers
High Rev springs
Chrome moly steel retainers
Auto Craft chrome moly head studs (additional studs added)
Mellings oil pump (high output/steel)
Kennedy HD clutch
Kennedy HD pressure plate
All tin powder coated semi gloss black
New header and muffler ($550 new)
*Case
Machine work done by Rimco/Riddle machine
Large through bolts
Additional head studs added
Oil gallries welded
Clearanced for Stroker application
pris 50.000nkr
thomas lybbe
« Svar #1 på: september 02, 2009, 10:44:44 am »
så er det nu du har chancen for at få en sindsyg motor til langt under byggepris/dele
den der ligger 10% først for denne motor for 38.000nkr incl fragt til norge
