august 09, 2026, 05:17:38 am *
Skrevet av Emne: Fuchs-felger; et grunnkurs...  (Lest 5501 ganger)
« på: september 03, 2009, 10:26:19 am »
Jeg trenger noen som kan dette 101%... til å forklare oss litt om Porsche 911 Fuchs felger fra før 1975 - den tidlige "hjerte"-versjonen altså.
Jeg vet de kom på S-modellen i 1967 i dim 15x4,5.
Deretter i 1968 i dim 15x5,5.
Men....når kom det  flere ulike bredder av 15-tom?...6-tom "deep" og "flat" feks?
Og...når kom 14 og 16 tom felgene?
Noen som har satt seg ordentlig inn i dette? Årsmodeller og dimensjoner fra før 1975.
Interessant:
http://www.themotoringjournal.com/cars-for-sale/refinishing-fuchs-at-home.html
* Revestreker.jpg (54.86 KB, 800x532 - vist 278 ganger.)
Jærva
Bosted: Østlandet.
« Svar #1 på: september 03, 2009, 16:32:31 pm »
Vet ikke om dette hjelper deg noe men.. : http://members.rennlist.com/911pcars/WheelWts.html
http://forums.pelicanparts.com/showthread.php?t=478971
Her et utklipp :
The original “S” wheels are Fuchs 6Jx15 with 185/70VR15 tires. The ‘deep dish’ version from ’69-’71 do not have the ‘safety bead’ These are also now difficult to find and expensive.
The similar 6Jx15 Fuchs from ’71 through ’77 has the safety bead and is commonly available. Even perfect examples can be found at reasonable prices. Originally these came with 185/70VR15 but today it is common to use 195/60-15 tires.
You can fit a 7Jx15 and 205/55-15 to the rear if you are very careful.
The easiest and least expensive choice are the 6Jx16 Fuchs common on the front of 911SC and later. There are many ‘like new’ available. It is common for them to have been stored in garages with the rear 7Jx16 moved to the front and new 8Jx16 installed on the rear.
This wheel, with a 205/55-16 will fit on all four and will fit as spare. If your 911 sits low, you may need to pay attention to the front fender lip about 8” up in the front. Many cars (even with OE set-up) can have a new tire snag the lip.
There is far greater selection of appropriate tires with 16” diameter than there are for 15” wheels.
It is possible to fit a 7Jx16 and 225/50-16 in the rear. To do this, you need stiff springs to limit wheel travel and compromise alignment (2°+ negative camber) and consequent inside tire wear. There were sufficient differences in body position that this may not be a choice.
I hope you have stored away your “Comfort Package” for posterity. If not, I encourage you to do so. It will make a nice ‘wall hanging’ object d’art for your garage.
The details are important. With some preparation, this is an easy Saturday DIY project. Some is normal every 40-year maintenance, regardless of mileage.
Starting in 1970, when Porsche installed the Comfort Package they used 911E-only suspension components. These were the regular 911T/911S parts but partially completed. In particular, they were the front suspension cross member that supports the two A-arms and the steering rack and the two A-arms. The ends of the cross member lacked the provision for supporting the torsion bar lever. The A-arms lacked the splines for a torsion bar and the lower part of the structure out to the ball joint. The first thing to do is determine if you have these original parts or they are changed to the T/S parts.
Not installed were the torsion bars, adjusting screw, foam seal and lever arm. Of course all these came with the ‘self-leveling’ hydropneumatic struts. The common joke was they self-leveled collapsed on the rubber bump stops.
The good news is all these came with the aluminum caliper 911S brakes. These use the 3.5” support spacing struts.
« Siste redigering: september 03, 2009, 16:34:44 pm av Jærva » Loggført
erikaa
« Svar #2 på: september 03, 2009, 19:20:31 pm »
Mye Fuchs info på TheSamba også: http://www.thesamba.com/vw/forum/viewtopic.php?t=67203&highlight=fuchs
Reiel
« Svar #3 på: september 03, 2009, 19:44:55 pm »
14" Fuchs kom vel i 67-68 som et tilvalg for de som ville ha høyere dekkdimensjon på sin 911.
Mange syntes den ble litt "stiv" å kjøre med 15", mere komfort med de andre hjula. Dette ble mest gjort i USA...
Varte ikke mange årene dette tilbudet heller, ca 2 år mener jeg...
Reiel
Sonic
« Svar #4 på: september 03, 2009, 21:36:09 pm »
14 " fuchs kom ikke i 68-69 men i 71-72 , Ettertraktete felger er 6x 15 deep six (uten hjerte  pga styrke ) i motsetning til hva folk tror .
« Svar #5 på: september 03, 2009, 22:41:14 pm »
Litt OT, men smetter inn denne, ser ut til at Porsche selv er på "Fuchs-kjøret" igjen, nå med 19" retro Fuchs...
http://www.pistonheads.com/news/default.asp?storyId=20536
« Svar #6 på: september 03, 2009, 22:50:49 pm »
ja takk, de felgene hadde sitti fint på min 79' Karmann cab Osteaktig
