august 08, 2026, 07:16:53 am *
Skrevet av Emne: Noen som hadde vært interessert i HD 1080P videokamera til inboard eller utenpå?  (Lest 1952 ganger)
Danna
« på: januar 27, 2010, 20:08:12 pm »
Hei,
Vet ikke hvor jeg skulle legge denne, men prøver her..
Er det noen her som kunne vært interessert i å skaffe seg HD 1080P videokamera til inboard, eller til å feste utenpå bilen eller hvor man måtte ønske ? Artig lite kamera hvis man skal f.eks kjøre dragracing, eller evt. bare lage en koselig VW film! Glad
Ved interesse, kontakt meg på danna16vt@hotmail.com, evt PM her. Kameraet kommer på 3000,- inkl. moms og frakt.
Litt om kameraet :
1 HD camera
1 Rechargable 1100 mAh Lithium-Ion Battery
1 Waterproof Quick-Release Housing (180’/60 m)
3 Flat, 3M™ Adhesive Mounts
2 Curved, 3M™ Adhesive Mounts
2 Quick-Release Buckles
1 Vertical Surface “J-Hook” Buckle
1 Suction Cup Mount
1 Three-Way Pivoting Side Arm Assembly
1 USB Cable
1 Component Video (HDTV) Cable
1 Composite Video + Audio Out Cable
Warranty: One Year
1 Roll Bar/Tube Clamp
1 Three-way Adjustable Pivot Arm (three piece assembly)
Warranty: One Year
Litt info om kameraet :
Optikken:
Lens Type: Fixed Focus (2ft/.6m – ∞), glass
Aperture: f/2.8 (high performance in low-light situations)
Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
Angle of View: 127º wide angle in 1080p mode
Video:
1080p = 1920x1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
960p = 1280x960 pixels (4:3), 30 fps, 12 Mbit/s data rate
720p = 1280x720 pixels (16:9), 60 fps, 15 Mbit/s data rate
720p = 1280x720 pixels (16:9), 30 fps, 8 Mbit/s data rate
WVGA = 848x480 pixels (16:9), 60 fps, 8 Mbit/s data rate
Sensor Type: 1/2.5" HD CMOS, 2.2µm-sized pixels
Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
Exposure Control: Auto with user selectable center weighted average and spot metering settings
White Balance: Auto
Audio
Microphone: Built-in, mono with AGC (automatic gain control)
Audio Format: 48 kHz, AAC audio compression
Resolution: 5 megapixel
Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
Memory: SD card, up to 32GB capacity (SDHC)
Average recording times (using 32GB SD card):
1080p (30 fps): 4h 21m
960p (30 fps): 5h 26m
720p (60 fps): 4h 21
720p (30 fps): 8h 09m
WVGA (60 fps): 8h 09m
Camera Connectors & Cables
PC Connection: USB 2.0 (data connection and battery charging)
HDTV Out: HD NTSC & PAL (component cable incl.)
Audio Out: Combo 2.5mm jack with stereo audio and composite video out
PC Compatibility: Windows® XP (Service Pack 2 or later) or Vista; Mac OS® X 10.4.11 and later
Power & Battery
Battery Type: Rechargeable 1100 mAh lithium-ion
Battery Life: Approx. 2.5 hrs
Charging: via USB to computer or optional power adapter
Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
Waterproof Camera Housing
Depth Rating: Up to 180 feet / 60 meters
Construction: Polycarbonate and stainless steel
Hardware: Stainless steel
Size & Weight
Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
Optional Accessories
Additional Rechargable 1100 mAh Lithium-Ion Battery (not yet available for pre-order)
Full Line of Mounting Accessories
Optional Expansion Bakpacs™
An innovative expansion port on the back of the camera, the HERO Bus™ accepts optional Expansion Bakpacs to expand the functionality of HD HERO cameras:
LCD Bakpac for on-camera preview and playback (not yet available for pre-order)
Endurance Battery Bakpac for double battery life (not yet available for pre-order)
More Bakpacs and expansion devices coming soon
* 683_large_CHDMH-001-05-683x426.jpg (75.73 KB. 683x426 - vist 150 ganger.)
* 683_large_CHDMH-001-01-683x426.jpg (98.28 KB. 683x426 - vist 155 ganger.)
* 683_large_CHDMH-001-07-683x426.jpg (21.8 KB. 683x426 - vist 139 ganger.)
Ønsker å kjøpe Splitt Pickup eller Panel.
  • 58' VW 113
  • 58' Karmann Ghia
  • 66' Ragtop
« Svar #1 på: januar 27, 2010, 22:11:48 pm »
Hørtes dyrt ut... Øyerulling
Norbeck
Bosted: Nes i akershus
« Svar #2 på: januar 27, 2010, 22:26:44 pm »
står pris 3000... ikke så ille det
nesligaen vw klubb
vw1961
Bosted: birkeland
Originalnostalgiker
« Svar #3 på: januar 27, 2010, 22:29:46 pm »
tja... begrenset hva det kan brukes til, men tekonolgi, oppløsning kontra pris er ikke dyrt.
Praise the aircooled
Kjøreglede, det er å ta for seg hele alfabetet i steden for  A til B:=)
Danna
« Svar #4 på: januar 27, 2010, 22:31:04 pm »
Spørs vel om man får noe bedre ytelse for samme pris noe annet sted vel Glad Mye for pengene her..Dette er selvfølgelig ikke brukbart som håndholdt, men det følger med en god del monteringsdeler..
  • 58' VW 113
  • 58' Karmann Ghia
  • 66' Ragtop
Even Kirknes
« Svar #5 på: januar 29, 2010, 19:54:16 pm »
Samme kamra som jeg kjøpte og monterte på sykkelen jo,  nesten dobbelt så dyrt bare. 1800kr levert på 14 dager fra statene.
