august 09, 2026, 23:17:33 pm *
Skrevet av Emne: bensin trykk  (Lest 2156 ganger)
vwkalle
Bosted: Ålesund
« på: april 16, 2010, 17:49:32 pm »
Hei
Kan nokken hjelpe me .
Har 2,1 l me 45 dobble weber hva bør trykket vere fra bensinpumpa bør en ha regulator å hvor har de de i tilfellet Gliser TAKK.
« Svar #1 på: april 16, 2010, 18:31:15 pm »
44 IDF bruker 3 psi. Er det dcoe (liggende) du har?
vwkalle
Bosted: Ålesund
« Svar #2 på: april 16, 2010, 20:33:43 pm »
Hei ja e har   DRLA   Gliser
« Svar #3 på: april 16, 2010, 21:16:17 pm »
CARB SET UP
Step 1 Check Your Fuel Pressure
Carburetors are designed to operate with a certain fuel pressure, and if this range is not met, the carbs will flat out not operate properly. Solex and Kadron Carburetors should have 1.5 - 2 PSI fuel pressure. All Dellorto and Weber Carburetors should have 3 - 3 .5 PSI. Your local autoparts store, or Sears sells a combo vacuum pressure gauge for $19.95 which you T-in at the carburetor to measure fuel pressure. If the pressure is excessive based on your carb type, how you bring it down within spec depends on what fuel pump you have. Electric pumps use our Holley or Mallory Fuel Pressure Regulator, while engines with a stock fuel pump simply stack gaskets between the pump and spacer to drop pressure. Do not make the novice mistake of assuming that because you have a stock pump that your pressure "must be okay"! We have seen the stock pump put out over 10 PSI which will flood ANY carburetor that you bolt on your engine.
vwkalle
Bosted: Ålesund
« Svar #4 på: april 16, 2010, 21:26:37 pm »
Takk for super hjelp Gliser Gliser
« Svar #5 på: april 16, 2010, 21:59:50 pm »
 Blunker Bare hyggelig.
