juni 10, 2026, 13:06:03 pm
Scat #20176 LARGE DIAMETER SPRING-LOADED PUSHROD TUBES
Emne: Scat #20176 LARGE DIAMETER SPRING-LOADED PUSHROD TUBES (Lest 1704 ganger)
Eivind E
november 20, 2010, 23:29:04 pm »
"20176 - SCAT - NEW STYLE LARGE DIAMETER HI-PERFORMANCE ALUMINUM SPRING-LOADED PUSHROD TUBES - WITH DUAL O-RINGS DESIGN - SET OF 8 - ALL BEETLE STYLE 1600CC ENGINES"
"These are the finest pushrod tubes we offer. Made by Scat enterprises. These larger diameter spring loaded tubes are perfect for any larger stroker engine with or without hi-lift rocker arms. They adjust to any width engine and with there dual o-ring design, provide the best sealing of any adjust tube on the market.
Eliminates pushrod rubbing against tube walls
Spring loaded for sealing tension + easy installation
6061-T6 sleeves are sealed together with Viton O-rings
Clearanced for high lift camshafts and rockers
20% Bigger in diameter than stock"
Dvs. fjærbelasta pushrod tubes i aluminium, med større diameter.
Selges kr 500 eller beste omtrentlige bud.
Ny i forpakning.
(47.63 KB, 300x300 - vist 124 ganger.)
(79.21 KB, 640x478 - vist 129 ganger.)
(83.44 KB, 640x478 - vist 115 ganger.)
Siste redigering: november 20, 2010, 23:32:04 pm av Eivind E
65 Karmann Ghia @ 2332
66 1300 @ 1914
72 Doka @ 2.4
Sv: Scat #20176 LARGE DIAMETER SPRING-LOADED PUSHROD TUBES
november 21, 2010, 11:39:13 am »
Kan ta de for 500,-
vidars
Bosted: Aurskog
november 21, 2010, 15:28:36 pm »
jeg byr 600.
Eivind E
november 21, 2010, 21:42:06 pm »
Sitat fra: vidars på november 21, 2010, 15:28:36 pm
jeg byr 600.
Da sier jeg solgt, kom og hent
66 1300 @ 1914
72 Doka @ 2.4
vidars
Bosted: Aurskog
november 22, 2010, 17:40:44 pm »
send meg tlf nr på pm, så tar jeg kontakt.
Vidar.
Eivind E
november 23, 2010, 04:13:19 am »
Pm sendt
66 1300 @ 1914
72 Doka @ 2.4
