juni 21, 2026, 14:57:14 pm *
Skrevet av Emne: Lagt til mere deler som selges.  (Lest 6117 ganger)
GeirH
« på: januar 13, 2011, 19:23:46 pm »
Litt copy og paste....
Stock ratio or 1.25 ratio cam.
1 stk: DRD 280 Cam, 280 duration, .444 lift (Excellent torque cam on any size engine, bus and off road).  800,-
Ratio Rocker cam 1.4 or 1.5
1 stk: DRD R302 Cam, 302 duration, .530 lift( Hot street cam , 2000cc and larger, dual carbs and good heads, used in most of our 185+hp street engines, broad power band revs to 6700 rpms.     800,-
2 sett løftere: DRD type 1 chilled iron lifters, designed to be matched with chilled iron cam blanks only. All cams sold by DRD are to be used with these lifter sets. Lifters have been ground with the propper crown , to promote proper lifter spining. Sold in sets of 8. Elimiate cam and lifter failures with a proven combination.   800,- pr.stk
1 sett Vippearmer 1,4. Scat:
New type 1 scat rocker kits. Includes solid shafts, new blocks, lash cap set with extra side shim washers, sold pairs of 2.  These are the best forged rockers made, super strong, and quieter than rest, due to solid constuction. These rockers have Massive over sized, hardened adjusters, that will not wear out.   2000,-
Straight cut kam drev: DRD Type 1 Straight cut gear set.  500,-    SOLGT.
T-4, 2 liter veiv med tilhørende råder m/ ARP bolter.  2000,- Solgt.
Div. T-4 blokker. 2 brukte glassblåste og Alodine behandlet, samt 1 NOS.
ARP bolter til T-4 blokk. Case thru bolter 6 stk. samt pinnebolter for syl/topp 16 stk. 1000,- SOLGT.
T-4 topper, firkant eksos, glassblåste og igjensveiset plugghull.. Bud
Intermediate housing BILLET til 091 kasse. 3000,-
Komplett T-1 kasse m/aksler og tromler. fra 64 mod. bud.
IRS bakende, kappet 10cm. fremfor torsjonsrør, ikke bærearmer.
Komplett T-4, 1700 motor. W kode, innsprut.
Race stoler, ligner på noe hardplast greier, med trekk. Aldri brukt. MMS bilde
002 gearkasse fra 76 m/aksler
Motorluke splitt, pope nose m/pæreholder og glass. Håndtak med lås, ikke nøkkel. Bra stand, til å være 60 år gammelt.
Lemmertz Sprint Star, 4x130.  4,5x15 felger, 4 stk. Urørte, og patina deretter, men ikke gæli.. Kan sende bilde på MMS
Lemmertz Sprint Star 4x 130.  5,5x15 felger, 4 stk. Fine og dype. Lakkert i hvitt og svart... Kan sende bilde på MMS
T-4 innsug, for 2 stk dobble, passer DRLA/IDF gassere.  MMS bilde.
Oljekjøler, ekstern. ca 30x18 cm. Hang under Ghia'n i sin tid. Hydrauliske slanger sitter på. Med flaks så passer de og.... MMS bilde
H beam, Scat råder. NYE. 5,4" med VW journal.  2000,- Solgt.
JE stempler, smidde. 4"/101,6 mm. 4000,-
Magirus Deutz sylindere. 100 mm. borring.  Må maskineres. Gromme ting til din 4 tommers wasserboxer motor.  :-)
T-4 Blokk. Maskinert for Porsche vifte og 103/105 mm sylindere.
« Siste redigering: februar 14, 2011, 08:43:34 am av GeirH » Loggført
Har laaang VW-pause.
Hulken
Hardcore type four...
« Svar #1 på: januar 13, 2011, 19:58:00 pm »
Tar ARM boltsett til T4 - sleng det oppi sandblåsekabinettet!   Blunker
Arild B, Gjøvik
1973 412 2-dørs coupe
tezer
Bosted: Hamar Hedemarken
« Svar #2 på: januar 13, 2011, 22:03:58 pm »
justerbart eller fast?
Vw 1302
VWdriver
Bosted: Asker
« Svar #3 på: januar 13, 2011, 22:18:36 pm »
Hei Geir
"002 gearkasse fra 76 m/aksler"
Hva slags kasse er dette? Hvilke bil er det til. Hva slags stand
Er på jakt etter en 1303 kasse 74-og senere.
Marius
GeirH
« Svar #4 på: januar 13, 2011, 22:24:17 pm »
Justerbart, dette er AA produkt. Følger med 3 sett med skiver for justering.
GeirH
« Svar #5 på: januar 13, 2011, 22:25:12 pm »
Hei Geir
Marius
Disse sitter i Transportere. Ikke bolt-on i bobler.
tezer
« Svar #6 på: januar 13, 2011, 22:30:47 pm »
Da tar  jeg det Straight cut kam drev: DRD Type 1 Straight cut gear set.  500,-
sender deg pm med adresse!
Vw 1302
GeirH
« Svar #7 på: januar 13, 2011, 23:04:44 pm »
Den er grei.
Hulken
« Svar #8 på: januar 13, 2011, 23:15:36 pm »
Du fikk med denne også?
Arild B, Gjøvik
GeirH
« Svar #9 på: januar 13, 2011, 23:18:12 pm »
Jada, står SOLGT nå.
SnowTrac
Snø, hvorfor ikke?
« Svar #10 på: januar 13, 2011, 23:31:51 pm »
Sendt deg en PM
-69 Trac Master ST4B (Snow Trac med brede belter)
-Hjemmebygd buggy(bygd på 1302 understell og et gammelt bilcross bur)
-2 stk golf 1 bilcross biler
-08 Bashan 200 ccm ATV
-hjemmelaget belte bil med vw t1 motor og girkasse
http://www.snow-trac.net/
vwpower
« Svar #11 på: januar 13, 2011, 23:39:47 pm »
Hei,er det komplett sprut på 1700?
« Svar #12 på: januar 13, 2011, 23:40:01 pm »
Trenger ikke lokket, men selger du kun pave nesa? Pris?
nord
Bosted: Finnsnes
« Svar #13 på: januar 13, 2011, 23:53:38 pm »
Interessert i motorlokket med pave nesen,pris?
1200 spareboble
Porsche 928 S4
1958 Plymouth
Harley Sportster "Ironhead"
Moto Guzzi V7R
GeirH
« Svar #14 på: januar 14, 2011, 09:04:24 am »
Komplett, minus hjernen som jeg mener skal ligge her ett sted.
GeirH
« Svar #15 på: januar 14, 2011, 09:05:02 am »
Nei.
GeirH
« Svar #16 på: januar 14, 2011, 09:06:55 am »
Fått endel PM'er på motorlokk.
Skal prøve å ta noen bilder og legge ut, så blir det høyeste bud på dette.
raaen
« Svar #17 på: januar 14, 2011, 11:04:52 am »
tar baklokket jeg. Prisen blir vi enige om. Levering som sist ?
GeirH
« Svar #18 på: januar 14, 2011, 21:21:29 pm »
Raaen: Spørs hva du byr det. :-)
Er ikke på G.moen lenger.....
Bobble 1300 Bc
« Svar #19 på: januar 16, 2011, 23:00:00 pm »
Pris på type 4 innsuga Er de 40 45 48mm bilde treffes på 90683225
Hulken
« Svar #20 på: januar 16, 2011, 23:13:45 pm »
Byr 400 for innsug
Arild B, Gjøvik
GeirH
« Svar #21 på: januar 16, 2011, 23:21:48 pm »
Notert, med bitteliten skrift  Blunker
1303RCN
Bosted: Hedemark
« Svar #22 på: januar 16, 2011, 23:48:36 pm »
Har en 103 syl sats som trenger ei blokk med 107mm hull for sylinderene, er det det i den freste blokka du skal selge så kan jeg være interisert i den, hvis prisen er "riktig"  Blunker
GeirH
« Svar #23 på: januar 20, 2011, 16:00:25 pm »
OPP
