august 10, 2026, 16:31:10 pm
S:NYT Komplet CSP Disc Brake 5x130 type 2 bus 55-63
Emne: S:NYT Komplet CSP Disc Brake 5x130 type 2 bus 55-63 (Lest 1016 ganger)
thomas lybbe
august 10, 2011, 13:40:11 pm »
This CSP disc brake system is designed for all Buses from 1950 to 1970 and has the popular 5x130 PCD (also known as Porsche PCD). It is characterized by its tremendous reliability and the fact that it is TÜV approved!
The CSP disc brake is basically a hub/disc combination and its simple construction makes it applicable on most aircooled Volkswagens. The CNC machined cast alloy hubs accept discs made in Germany with a diameter of 282x9 mm through high-strength connecting elements. The modified calipers are also from a German mass production manufacturer.
Based on the unmodified axle components of the respective cars the CSP disc brakes are mounted to the original spindles by CNC machined adapters. There is no need to modify or alter the spindles, which makes it easy to swap back to the original drum brakes if requested.
A TÜV certification is available for all disc brake systems listed on this page. It is included in your order if it is of relevance in your country
pris 7500dkr leveret til scc
(41.6 KB, 400x300 - vist 112 ganger.)
thomas lybbe
Sv: S:NYT Komplet CSP Disc Brake 5x130 type 2 bus 55-63
august 13, 2011, 20:09:04 pm »
Så er er det sidste chance 7500dkr . leveret gratis incl told og moms til scc .. skal ha svar senest imorgen søndag kl 2100
thomas lybbe
august 15, 2011, 21:02:37 pm »
6800dkr
thomas lybbe
august 17, 2011, 19:53:36 pm »
Sidste chance imorgen kl 0800 hvis der er nogen der vil købe
