august 02, 2026, 13:00:37 pm *
Skrevet av Emne: CSP 5 x 205 bremser (linkpin)  (Lest 3905 ganger)
TomR
« på: november 06, 2011, 01:23:40 am »
Bare testmontert, aldri kjørt med - skivene er litt brune etter lagring - men dette forsvinner fort (ikke gravrust). Dette er tysk kvalitet, og ikke noe kinagreier, kalippere er av merke ATE!
Gi bud!
* 2011-11-05 16.43.07_norge.jpg (82.92 KB, 600x800 - vist 302 ganger.)
« Siste redigering: november 06, 2011, 15:22:06 pm av TomR » Loggført
Lasse.E
« Svar #1 på: november 06, 2011, 01:29:14 am »
Er disse til org.spindel eller Cb ?
Mvh.Lasse E
TomR
« Svar #2 på: november 06, 2011, 01:31:17 am »
Org spindel!
raaen
« Svar #3 på: november 06, 2011, 10:34:49 am »
2000.- kr
Lasse.E
« Svar #4 på: november 06, 2011, 12:38:44 pm »
3000.-
Mvh.Lasse E
Race-buggy
Bosted: sørlandet
boblekameratene
« Svar #5 på: november 06, 2011, 15:02:51 pm »
er det TUV på dette bremse kitet ? og hvilket offsett er det på dette ?
« Siste redigering: november 06, 2011, 15:05:11 pm av Race-buggy » Loggført
Race-buggy.
black bullet-59 boble
TomR
« Svar #6 på: november 06, 2011, 15:08:14 pm »
Jeg har ikke TuV papirene på det, men jeg ser de skriver:
The CSP disc brake system with 5x205 PCD is available since 1997 and is meanwhile tried and tested a thousand times! It is characterized by its tremendous reliability and the fact that it is TÜV approved!
The CSP disc brake is basically a hub/disc combination and its simple construction makes it applicable on most aircooled Volkswagens. The CNC machined cast alloy hubs accept discs made in Germany with a diameter of 282x9 mm through high-strength connecting elements. The modified calipers are also from a German mass production manufacturer.
Based on the unmodified axle components of the respective cars the CSP disc brakes are mounted to the original spindles by CNC machined adapters. There is no need to modify or alter the spindles, which makes it easy to swap back to the original drum brakes if requested.
A TÜV certification is available for all disc brake systems listed on this page. It is included in your order if it is of relevance in your country.
Tror kanskje settet er Tuv godkjent i den senere tid, så jeg tipper man får disse papirene ved å henvende seg til CSP - men jeg vet ikke. Nypris på settet er 1000EUR, så vi er et stykke unna halv pris ennå Glad
TomR
TomR
« Svar #7 på: november 06, 2011, 15:19:15 pm »
Settet bygger ca 12mm per side, CSP selger også et såkalt Zero Offset kit, men også det bygger 3,5mm på hver side (så ikke helt ZO), dette kitet har da ikke bremseskjold og bruker aluminium adaptere for kalipperene - de jeg selger har bremseskjold i rustfritt og har stål kalipperadapter.
Vær obs på at dette settet kun er brukbart med 15" og større hjul!
raaen
« Svar #8 på: november 06, 2011, 16:02:31 pm »
4000.-
TomR
« Svar #9 på: november 07, 2011, 21:49:15 pm »
Lar budrunden gå til 2100 i morra..
TomR
« Svar #10 på: november 08, 2011, 21:03:18 pm »
En time igjen før skipsklokken slår Osteaktig
TomR
« Svar #11 på: november 08, 2011, 22:07:15 pm »
Grattis til Raaen med ubenyttede bremser til under halv pris av butikkpris (i Tyskland, men delene skal og hit om momses inn), folk kjenner virkelig ikke sin besøkelsestid her...
raaen
« Svar #12 på: november 08, 2011, 22:10:52 pm »
 Glad  konto nr ?
« Svar #13 på: november 08, 2011, 22:16:20 pm »
singha og chang!  Rekker tunge Kult
TomR
« Svar #14 på: november 08, 2011, 23:14:10 pm »
Solgt og betalt, takk til Raaen!!
Glad  konto nr ?
TomR
« Svar #15 på: november 08, 2011, 23:14:29 pm »
Ikke Chang!
« Svar #16 på: november 08, 2011, 23:15:30 pm »
skal jeg tørste !!???
TomR
« Svar #17 på: november 08, 2011, 23:27:48 pm »
Neida, vi heller vann i deg Jørn, det er best slik!!!
* tangus_changus_web.JPG (102.62 KB, 800x1067 - vist 164 ganger.)
Solan
« Svar #18 på: november 09, 2011, 23:58:46 pm »
Det der så j*vli godt ut....
'52 Typ 11c Boble ragtop
'65 Typ 221 Mikrobuss 11W
Sonic
« Svar #19 på: november 10, 2011, 05:30:05 am »
Fler som koser seg i solen.. Hæ Gliser Gliser
Erich
« Svar #20 på: november 11, 2011, 01:08:18 am »
ikke ennå erich... 14des. krungthep-kohchang-kohsamui!!   Kult
Sonic
« Svar #21 på: november 11, 2011, 05:28:50 am »
Ok .
Kl 10 snart , 28 grader , sol fra skyfri himmel og solkremen er snart tom igjen ...
Hjemme i huset men drar til Koh Chang på mandag ..håper dere får en fin tur i jula.....
Pål, (orangenotch), kom til Jomtien i går, (loykatong ), og skal etter sigende ha hatt et vått førstedøgn  Gliser
Erich
