august 09, 2026, 09:24:57 am *
Skrevet av Emne: Bremse skiver t1  (Lest 734 ganger)
mags
Bosted: Sølvbyen
« på: november 10, 2011, 18:25:44 pm »
Ok Brukte bremse skiver 4*130mm.
et sett med pressa inn studs kr350,-
et vanlig kr200,-
Mags
90508914
Good Work ain`t cheap
Cheap work ain`t good
Mags  90508914.
Bosted: Nittedal
Tlf: 92 02 17 53
« Svar #1 på: november 10, 2011, 18:42:27 pm »
Tar de med studs vis du kan sende.
You need only two tools: WD-40 and duct tape. If it doesn't move and it should, use WD-40. If it moves and shouldn't, use the tape!
1953 Barndoor panel
1969 Bay panel
1969 Boble
1988 Caravelle
1999 Caravelle
2000 Transporter panel
mags
Bosted: Sølvbyen
« Svar #2 på: november 10, 2011, 19:44:56 pm »
ja
se pm
da
Mags  90508914.
