august 06, 2026, 15:11:04 pm
Flat4 4-Tip Exhaust 1300-1600 type 1 (SOLGT)
Emne: Flat4 4-Tip Exhaust 1300-1600 type 1 (SOLGT) (Lest 1739 ganger)
februar 20, 2012, 21:22:49 pm »
Selges for kr. 3000,- Rustfritt. Kvalitet. Nytt i eske!
Klipp og lim fra CSPs hjemmeside:
With the new 4-Tipp Muffler Flat4 and Wolfburg West surprises the Vintage community with a high quality and outstanding product. Exclusively developed by CSP the new Flat4 & Wolfsburg West 4-Tip Muffler matches the genuine 4-Tip Muffler in all essential details like the two typical crimps and the complex inner layout of the muffler. The black wrinkle finish and the four polished end pipes gives the new 4-Tip Muffler the typical Vintage look and the distinctive 4-Tip sound. The use of stainless steel guarantees high corrosion durability.
The new 4-Tip Mufflers are available in two versions, matching all Beetle and Karman Ghia Type-14 with either 30hp engines or all 1300 - 1600 ccm engines.
classic Vintage look
typical sonorous 4-Tip sound
matches the genuine 4-Tip muffler in all essential details
made of stainless steel for high durability
assembly kit with pipe clamps emphasizing the original included
(50.37 KB, 400x300 - vist 104 ganger.)
Siste redigering: mars 04, 2012, 16:51:40 pm av Jøran Larssen
haug57
Sv: Flat4 4-Tip Exhaust 1300-1600 type 1
februar 20, 2012, 23:36:32 pm »
Har du tilsvarende til 30hk også?
februar 20, 2012, 23:42:07 pm »
Sitat fra: haug57 på februar 20, 2012, 23:36:32 pm
Nei, kun det jeg har annonsert.
Kjell Tormod Brekka
Bosted: Kragerø
februar 20, 2012, 23:59:58 pm »
Komme rørene ut ca i hull i bakplate eller går de under? Flott potte ja!!
Tlf 993 67 911
Seaside VW- Club
‘67 T1 1500
‘67 912 Coupe
+Div andre ‘67 prosjekt
februar 21, 2012, 00:23:00 am »
Sitat fra: 91167coupe på februar 20, 2012, 23:59:58 pm
Ikke cirka. Disse kommer ut i/rett under hullene i bakplata. Topp kvalitet med fin lyd også.
februar 23, 2012, 17:38:21 pm »
Svar #6 på:
mars 02, 2012, 20:20:58 pm »
Skulle du være fristet, så finner du ikke billigere aternativ!
vk
Svar #7 på:
mars 03, 2012, 23:53:55 pm »
Hei.
Jeg kjøper den av deg ,se PM.
Mvh Vidar
