august 06, 2026, 13:35:04 pm
carter bensinpumpe pluss regulator
Emne: carter bensinpumpe pluss regulator (Lest 1154 ganger)
assy
Bosted: Sandefjord
mars 17, 2013, 12:32:36 pm »
600.- pluss frakt.
Bilde kan sendes
Asbjørn 4168200
vwsteinar
Bosted: Sunndalsøra
-62 T1, -80 T25, -65 T3 Racerbil.
Sv: carter bensinpumpe pluss regulator
mars 17, 2013, 15:32:54 pm »
For forgasser eller innsprut
Vwsteinar
assy
Bosted: Sandefjord
mars 17, 2013, 18:56:11 pm »
Hei
Originally created for military use, this design has been in production longer than any other Carter model. Rotating vanes driven by a heavy-duty wet motor deliver pressure from 4 to 18 psi at a flow rate of up to 100 gallons per hour. This provides excellent lift and prime capability. The pump is available in 6-, 12- and 24-volt versions. It is appropriate for RV, marine, agricultural, industrial and performance applications.
Jeg har brukt dette båd på IDA og efi system.
regulatoren ble sist brukt på efi, det er en malpassi regulator
Asbjørn
vwsteinar
Bosted: Sunndalsøra
mars 18, 2013, 09:56:27 am »
Starter med 400,- + frakt
vwsteinar
