juli 11, 2026, 06:46:05 am
Rullebelter i 1303 Cab - `Kan belter fra T25 /T3 Buss brukes - Se her...
Emne: Rullebelter i 1303 Cab - `Kan belter fra T25 /T3 Buss brukes - Se her... (Lest 1366 ganger)
juni 21, 2013, 23:58:33 pm »
Via en bekjent i miljøet som ikke er her på forumet har et spørsmål dukket fra en arbeidskollega av ham i utlandet. Jeg limer inn spørsmålet her:
" Do you know if the automatic-fasten-seat belts from BUS T3 fitted in an VW Käfer Cabrio 1303 ? I need them " longer " -----> "Belly fat"
Svar/forslag i tråden...
RuneA
Bosted: Oslo/Tallinn
Sv: Rullebelter i 1303 Cab - `Kan belter fra T25 /T3 Buss brukes - Se her...
juni 22, 2013, 00:49:54 am »
Dont eat McDonalds every day, or adjust the seat backwards.
1987 Westfalia
1980 Westfalia
1972 Westfalia
JFP
Bosted: Bærum
juni 22, 2013, 23:16:58 pm »
Du kan si dette:
Seat belts were installed by each country's importer, and there were many types. Just use one from a standard 1303. They are more than long enough. A t2 or t3 probably have a different bracket between the seat, and most likely won't fit.
juni 23, 2013, 00:17:38 am »
Har sendt videre. takker!
