august 09, 2026, 05:37:38 am *
Skrevet av Emne: Megasquirt EFI, The Dub Shop German kit  (Lest 1770 ganger)
Bjørn Hjellestad
member of slow children & Niceprice Racing
« på: august 06, 2013, 12:41:38 pm »
http://www.forum.vwacb.com/index.php?topic=6504.0
Hello!
Donwsizing i sortementet, solgt alle boblene, har noe fine deler for slag, selges som et komplett kit:
EFI bygget med utgangspunkt i Tysk hardware, plenum, trottlebody, mm
Megasquirt MS2 V3
Relayboard
Quadspark
Coil on plug
Innovate Lambdasonde med instrument
osv
100psi pressure - plus wiring, added circuit    1    $90,00   $90,00
Used pulley - Boost pulley and sensor bracket    1    $100,00   $100,00
Delsum    $190,00
Frakt og administrasjon    $11,00
PayPal (2,9%)    $5,51
Sum    $206,51 USD
German based EFI kit - Complete kit excluding air filter element    1    $1 600,00   $1 600,00*
Relay Board - w/fuses and power wires     1   $90,00   $90,00*
Relay Cable - All positions filled     1   $75,00   $75,00*
Wire bundle - 12 foot wire bundle included     1   $0,00    $0,00
Fuel injectors 24# - Standard injectors    1    $0,00   $0,00
Fuel pump kit Walbo 255lph - Kit standard pump    1    $0,00   $0,00
ECU upgrade - V2.2 ---> V3 Main Board     1   $74,95   $74,95*
ECU upgrade - MS1--->MS2 processor upgrade    1    $100,00   $100,00*
Map Daddy - 4bar w/ barometric correction     1   $64,95   $64,95*
Quad Spark - For driving COP's     1   $89,00   $89,00*
COP ignition coil - Short for type1     4   $27,50   $110,00*
COP ignition coil - Connector     4   $5,50    $22,00*
COP coil brackets - mounting brackets    2    $8,00   $16,00*
VR bracket - VR sensor bracket type 1     1   $9,95    $9,95*
VR sensor - Hidden VR sensor for type 1    1    $49,95   $49,95*
Machining - Machining of a type 1 pulley for hidden trigger wheel    1    $40,00   $40,00*
3 pin Delphi VR connector - For VR sensor, watherproof    1    $8,00   $8,00*
Steel Pulley - For trigger wheel     1   $75,00   $75,00*
Trigger wheel hidden - Hidden trigger wheel for type steel pulley    1    $40,00   $40,00*
Distributor Plug - To fill distributor hole     1   $20,00   $20,00*
LC-1 Wideband - With red dash gauge     1   $205,00   $205,00*
Air Filter - Standard cone filter element     1   $20,00   $20,00*
Delsum    $2 709,80
Frakt og administrasjon    $115,00
PayPal (2,9%)    $78,59
Sum    $2 903,39 USD
Totalen er 3.100USD + MVA
Gi Bud
http://thedubshop.goodsie.com/embed/german-kit-lite?extkey=888c41d8-a4ff-494f-9a8d-f90a5f176446
* EFIGermankit.jpg (65.28 KB, 400x400 - vist 556 ganger.)
