juni 11, 2026, 15:25:25 pm *
Skrevet av Emne: 90,5 Mahle sats, Engle FK10, Cb alu toppdeksel og innsug 2x48 idf/drla  (Lest 872 ganger)
Frid
Bosted: Ringsaker
« på: mai 01, 2014, 11:49:24 am »
Mahle 90,5 stempler og sylindre 4 stk kun gått få km  kr 1500,-  SOLGT
Engle FK10 ny , klarert for langslag og råder kr 500,-
The Engle FK10 is a classic VW Cam for serious engines. It is designed for 1.4-1.5 rockers, and it's specs are .385" Cam Lift, .539" Valve Lift (1.4 Rockers) 310 degrees of advertised duration, and 266 degrees of duration at .050", on a 108 Lobe Center.
This is the next step up from the FK-8, with a 3500-7500RPM Powerband which pulls hard! Expect a rough but manageable idle with dual 2bbl carburetors, do not even think about it with anything else!
Dual springs are REQUIRED. EXCELLENT HOT STREET and Mild Race cam! Works best with Compression from 9.5-10:1
CB alu toppdeksler med pakninger og bolter, nye kr 350,-
2 stk Innsug for 48 idf/drla sveist og porta for wedge topper . Noe arbeid gjenstår kr 300,-
Tlf 46913798
* 90.5.jpg (98.53 KB, 700x393 - vist 140 ganger.)
* cb.jpg (116.16 KB, 700x393 - vist 149 ganger.)
* innsug.jpg (123.4 KB, 700x393 - vist 137 ganger.)
« Siste redigering: mai 19, 2014, 22:14:32 pm av Frid » Loggført
1967 notch
1968 Variant 1600L
1966 karman ghia
1968 Variant 1600
Frid
Bosted: Ringsaker
« Svar #1 på: mai 19, 2014, 22:15:04 pm »
Sylinder sats solgt
1967 notch
1968 Variant 1600L
1966 karman ghia
1968 Variant 1600
