august 03, 2026, 10:06:00 am *
Skrevet av Emne: 4-valve DOHC flat four engine  (Lest 4608 ganger)
Bugat5speed
« på: juli 06, 2008, 14:41:07 pm »
Hi together,
might be that nobody knows me in Norway, but wanted to give a info on my current project.
Have engineered and am currently doing a 4-valve DOHC flat four for Beetles and classic 4-cylinder-Porsche (356, 912, 914), or other similiar cars. Do the project together with Robert Bernauer from RMB (www.rbernauer.de)
Heads, camboxes and other parts are completely new construted. Am working with 3D-CAD and also have my own milling centre.
2nd batch of heads were casted some weeks ago and were milled 2 weeks ago. I hope to be able to attach an image. The engine will be with a 5 bearing crankshaft and will by this easily revv more than 8.000 and will stand this.
Engines will be between 2.000 and 2.500 cc. We expect 100 PS per 1.000 cc for the start.
The engine will look a little like a classic engine (f.e. Porsche Carrera Fuhrmann engine). The cams will be beltdriven.
If you are intersted I will keep you informed on the matter. Sorry for English only!!
Martin Bott
Bug @ 5-Speed
www.bugat5speed.de
info@bugat5speed.de
*  (177.78 KB, 600x450 - vist 502 ganger.)
« Siste redigering: juli 07, 2008, 14:39:08 pm av Bugat5speed » Loggført
« Svar #1 på: juli 07, 2008, 00:20:40 am »
Hi Martin!
This looks exciting, please keep us updated on the progress and testing!
Good luck and brgds! Glad
Bugat5speed
« Svar #2 på: juli 07, 2008, 09:27:26 am »
Hi,
tried to add some pictures, but it somehow doesn´t work. Sorry for this!
Lövdal
Bosted: Gratangen
« Svar #3 på: juli 07, 2008, 11:06:19 am »
Hi,
Keep it coming!
This sounds like something for me Glad
Just ask if you need help adding pictures!
/N.
VW-55 (2,3L, Megasquirt, Turbo, IC, (5-vxl. UN1 låda))
VW-65 (Kawasaki ZX14, Megasquirt + turbo)
VW-75 1303 (2,3L, Megasquirt, Turbo, H2O IC, 5vxl. UN1 med diff)
KG 1960 (1915cc Megasquirt)
Mercedes 320 Carlson tuning.
Teistböen 1961 30 foot fiskebåt
Bugat5speed
« Svar #4 på: juli 07, 2008, 11:55:09 am »
Hi Lövdal,
thanks for your help. Yes I would like to post some pics, but how can I do this in this forum? Don´t understand either how big the pics could be. Can also write me a mail (info@bugat5speed.de).
Thanks
Lasse
Bosted: Våland - Stavanger
« Svar #5 på: juli 07, 2008, 12:08:03 pm »
Try uploading the images to photobucket.com, and then copy the "img" link into the tekstfield of your post Glad
california über alles
http://www.diekaeferloge.com/
Lasse `65
LUFTLIGA`N
« Svar #6 på: juli 07, 2008, 12:37:18 pm »
Hi Lövdal,
Thanks
The pics must be smaller than 256kB and you use the "ekstra valg"-button/text on the left when you scroll down after you finished your textwriting. Then you can browse your files and add.
Bugat5speed
« Svar #7 på: juli 07, 2008, 14:40:57 pm »
Hi,
thanks for the info. Could install a first picture. Will have to prepare some others.
