august 17, 2026, 20:41:51 pm *
Skrevet av Emne: Painless Universalt Ledningsnett  (Lest 2216 ganger)
Svang
Bosted: Gol
« på: juni 04, 2014, 00:26:16 am »
Selger ett nytt universalt ledningsnett fra Painless.
Perfekt for stripe/bane/gate-biler som trenger alle elektriske funksjoner.
Utklipp fra nettsiden deres:
Use this 12 circuit fuseblock and harness to operate your street legal race car's circuits with the included 8 switch panel.  Fuseblock provides fused outputs to turn signals, wipers, hazard switch, stop switch, electric fan, radio, gauges, headlights, dome light, electric water pump, electric fuel pump, coil and an accessory.  Switch panel provides switches for start, ignition, electric fan, fuel pump #1 and #2, water pump, headlights/tail lights and accessory.
 Harness wires are labeled every 12 inches with circuit description.  Kit comes complete with GM turn signal switch connector and two headlight pigtails.  Also included are tie wraps, grommets and fuseblock mounting bracket for easy installation and an illustrated instruction manual.
Switch panel may be dash mounted or roll bar mounted.
* Painless.jpg (10.14 KB. 315x315 - vist 311 ganger.)
PRIS 4000
Svang
Bosted: Gol
« Svar #1 på: august 08, 2014, 13:27:48 pm »
Opp
1835cc
Bosted: trondheim
Luftliga`n
« Svar #2 på: august 12, 2014, 15:36:21 pm »
Byr 2000, -
Mvh Øyvind
Svang
Bosted: Gol
« Svar #3 på: august 15, 2014, 15:30:03 pm »
Tar med dette til SCC..
Svang
Bosted: Gol
« Svar #4 på: august 15, 2014, 18:30:21 pm »
SCC TILBUD
Førstemann til mølla med 3000 får dette..
90222903
Svang
Bosted: Gol
« Svar #5 på: september 08, 2014, 09:33:56 am »
PRISDUMP: 2500,-
