juli 28, 2026, 12:49:53 pm *
Skrevet av Emne: CB Builders choice engine kit CB1186  (Lest 1018 ganger)
vwfreaks
Bosted: Naglestad
« på: mars 13, 2015, 02:47:31 am »
Ønsker å kjøpe CB Builders Choice engine kit CB1186, noen forslag fra hvem/hvor ?
Alternativt hvorfor ikke ?
T1   1969 Stepside pickup
T1   1951 "Voltswagen"
       1952Tempo Matador
"Cut weld and drive"
« Svar #1 på: mars 13, 2015, 08:58:57 am »
Fordelen er jo at du slipper å bestille mange ganger etter hvert som du oppdager hva du mangler.
Men det blir ikke DIN motor men CB sin med begrensede muligheter til velge løsninger du gjerne hadde foretrukket om du bygde fra scratch  Blunker
Hvis du bestiller, har vi en fyr vi pleier å bestille fra som ordner det billig og raskt.
Features
•1186 - 200 HP 2332cc Builders Choice Engine Kit includes:
•2289 - Cam Only T-1
•1274 - AS41 Dual Relief Super Case - T-1 & 2, 84 x 94, Full Flowed
•2665 - Super Race Rods (Chevy Journal) 5.5" length (set of 4)
•1859 - Maxi 30 Full Flow Oil Pump
•1278 - CB High Performance Case Kit
•1537 - 28mm Ultralight Lifters (set of Kult
•1941 - Rear Main Seal - 13, 15, & 1600cc
•1804 - Main Bearings STD
•2672 - Clevite Chevy Rod Bearings
•1399 - Straight Cut Cam Gears
•1565 - Racing Push Rod Tubes (set of Kult
•1423 - 044 Super Pro Cylinder Heads (44x37.5) 94bore
•1493ug - VW650 Valve Spring Upgrade
•1706 - 4 Quart Ultra Wide Glide Sump
•1618 - Chromoly Push Rods - blank end (.058")
•1037 - 94mm Wiseco Forged Piston Set
•1038 - 94mm Mahle Cylinders
•1702D - C Channel Valve Covers (set of 2)
•1424 - Main Bearing Dowell Pins (set of 5)
•1999 - 8mm Deflector Plates - fits 13, 15, & 1600cc (set of 2)
•1904 - Case Washer Set
•1255 - Rubber-Coated Cam End Plug
•2673 - Super Race Crank - 84mm Stroke - Chevy Journals
•1390 - 94mm 0.060' thick - Copperhead Gaskets (set of 4)
•1303 - Forged Chromoly Lightweight Flywheel - 200mm (o-ring seal)
•1360 - Racing Gland Nut with Washer
•1229 - 8mm Chromoly Head Stud Kit - Dual Port
•1849 - Racing Camshaft Bearing Set
•1918 - Crankshaft Gear Assembly Kit w/Racer Spacer NO CRANK GEAR
•1577 - Forged 1.4:1 Rocker Arms w/.060 Rocker Shims
•1362 - End Play Shim Kit
•1908 - Case Lock Nut Kit
•1973 - Gasket Set - 13, 15, & 1600cc Dual & Single Port Engines
•1094 - 94mm x .145" Steel Barrel Spacers
•LABOR-CC-CS - CC Heads to 52cc
•LABOR-FLOW - Full Flow Case
•HP rating is based on Dual 48mm IDA Carbs, 1 3/4" Merged Exhaust (#3597), match ported big beef manifolds, compression is set at 10.5:1 using listed parts in kit. Premium fuel is required for this kit.
vwfreaks
Bosted: Naglestad
« Svar #2 på: mars 13, 2015, 19:42:22 pm »
Blir nok "MIN" motor uansett, vet hvilke deler i standard kit som jeg vil endre, samt har laget eget innsprut og vil lage egen eksos.
       1952Tempo Matador
