juli 29, 2026, 18:08:23 pm *
Skrevet av Emne: Digital Magnaspark II fordeler med innebygget MAP sensor +++ - ny i eske  (Lest 2048 ganger)
TomR
« på: november 09, 2015, 22:59:42 pm »
En fordeler som tar hånd om det meste (tekst under kopiert fra CB sine nettsider):
- 21 x 21 Fully programmable spark table
- Tune as you drive technology
- Built-in Data logging
- Built-in programmable Two-Step Rev Limiter
- Built in programmable High RPM Rev Limiter
- Built-in 2.5 Bar MAP Sensor
- Works on Normally Aspirated and Forced Induction Engines
- Fully adjustable RPM and load boundaries.
- Live Online Software Support (Internet Connection Needed)
- Precision CNC housing, Black Anodized Finish
- Roller Bearing shaft support for exact timing accuracy
Each MS-Digital Distributor is shipped with software, installation instructions, communication cable, fittings and vacuum plates for easy installation.
Det som selges er altså dette http://www.cbperformance.com/ProductDetails.asp?ProductCode=2014 + http://www.cbperformance.com/ProductDetails.asp?ProductCode=2015
Fordelerklemma er ikke i settet, mulig jeg brukte denne på en motor (husker ikke).
Pris er høyeste bud over 3000,- + evt frakt.
* IMG_3460.jpg (82.02 KB, 800x600 - vist 251 ganger.)
TomR
« Svar #1 på: november 09, 2015, 23:01:57 pm »
Spesifikasjoner..
* IMG_3464.JPG (78.45 KB, 800x600 - vist 210 ganger.)
TomR
« Svar #2 på: november 10, 2015, 10:21:45 am »
Solgt!
