juni 11, 2026, 15:46:52 pm *
Skrevet av Emne: NY Engle W110 kam selges/byttes  (Lest 910 ganger)
Koff1
Bosted: Kongsberg
« på: april 05, 2016, 14:10:26 pm »
Ønsker å selges en ny og ubrukt Engle W110 kam med nytt og ubrukt Engle kamdrev  for 1250,- + eventuelt frakt, eller byttes i Engle FK-10 eller tilsvarende.
Tlf: 920 54 769 Runar K.
The Engle W110 Classic VW Bug camshaft grind is designed for 1.1 or 1.25 rockers, and it's specs are .392" Cam Lift, .430" Valve Lift (1.1 Rockers), 284 degrees of advertised duration, and 247 degrees of duration at .050", on a 108 Lobe Center.
This is the most popular and best all-around street cam ever made for a VW engine. You can not use this with a stock carburetor, you really need at least 2bbls of carb (Centermount 2bbl, dual 1bbls, or dual 2bbls).
Expect a powerband of 1500-5800 RPMs, the more headwork and carburetion the better the low end will be.
You can get by with HD Single Valve springs and Bolt On Rocker Shafts. Use a compression ratio of 8-8.5:1.
If you choose to use this cam with 1.25 rockers, you will extend the top end to 6000
1974 1303S
Koff1
Bosted: Kongsberg
« Svar #1 på: april 06, 2016, 14:16:17 pm »
SOLGT
1974 1303S
