august 06, 2026, 23:32:22 pm *
Skrevet av Emne: Bernie Berman motor type 1 2498 ccm  (Lest 1850 ganger)
Per DK
« på: februar 16, 2017, 20:09:19 pm »
Bernie Bergmann engine
2498 ccm type 1 engine
Type 1 fan house
44 mm double carburetors. Acc pump 55. Air 180. Mains 145. Idle 55
Electronic ignition
Engine case AS 41 CNC machined-Shuffle pins
Full flow oil pump
Chromoly crank Nitrided
Chromoly 13 lbs flywheel
Chromoly gland nut with flat washer
Chromoly I og H beam rods – mains, rod
Double thrust bearings race proven camshaft
Cam SCAT C35: lift 434. Duration 288
Bolt on gear 31 mm wide base chronology lifters with center lube holes
Cime pistons and cylinders, rings, wristpins Teflon bottoms
Stainless steel or flared push rods tubes
Big valves Eliminator head 37/44
Stainless steel valves
Heavy duty springs
Chromoly retainers
Solid rocker shafts with swivel ball adjusters or chromoly ratio rockers with lash caps
Bolt on valve cover in aluminum
Hide away fat Boy stainless steel exhaust
Stage 3 clutch
Spark plugs Champion RA8HC
HK 194
Torque 279
Max rpm 6000
Compression 8:9701
Se http://www.bergmannvw.net/
For info om motor bygger
Motor sider i bil nu og kan høres i gang
Pris DKK 45.000,-
Kan eventuelt leveres i Oslo, Kristiansand
Hilsen Per
+45 4059 4059
* P_20170208_164525.jpg (49.63 KB, 800x450 - vist 431 ganger.)
* P_20170208_164534.jpg (60.35 KB, 800x450 - vist 392 ganger.)
* P_20170208_164540.jpg (43.3 KB, 800x450 - vist 335 ganger.)
* received_1205862939472532.jpg (104.48 KB, 800x600 - vist 350 ganger.)
