juli 23, 2026, 17:20:53 pm *
Skrevet av Emne: dellorto 52 drla  (Lest 3584 ganger)
tds
Bosted: ålesund
Terjes garage.
« på: august 10, 2019, 20:26:52 pm »
dellorto 52...ser i gammel hotshop katalog at dette kunne leveres.
Ble dette noen gang solgt i Norge, og var dette en "flopp"?
« Svar #1 på: august 10, 2019, 22:21:07 pm »
Hørtes heftig ut.
Var ikke stort å finne på nettet om dem, men fant dette i en tråd på Samba:
Um.... No, sorry you'll not see any actual 52mm DRLA's.
The only place they exist is in a hand-drawn image on the front of the Dellorto tuning manual, and in Kieth Sume's mind.
In order to have a set of 52's, Dellorto would have had to make new die cast tooling, as the 48's have little room for more butterfly.
In order to justify this expense, there would have been thousands of carbs produced. They would not be rare.
I have been dealing with Dellortos for about 30 years.... I have restored at least 500 carbs. I too wish they existed, but they do not.
- Joe
SCC   14,257
tds
Bosted: ålesund
Terjes garage.
« Svar #2 på: august 10, 2019, 22:54:40 pm »
oj!  hmmm rart at hotshop hadde det i katalogen sin med artikkel nr.
for meg hadde det vært et must have Gliser
men.. så ble det bare en drøm..... Øyerulling
« Svar #3 på: august 11, 2019, 01:53:12 am »
Kan jo være det er laget, selv om en kar på et forum mener det ikke finnes. Noen mener det finnes.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7194958
Hvis du ser det i en gammal HotShop katalog er det jo bare å ringe dem å høre hva det var for noe.
SCC   14,257
