august 06, 2026, 06:24:31 am *
Skrevet av Emne: nybygget 2332ccm torqer engine 48ida SOLGT  (Lest 2925 ganger)
thomas lybbe
« på: oktober 16, 2008, 09:27:11 am »
2332cc NEW TURNKEY
A1 side winder exhaust system 1 5/8 ceramic coated.
Black dual port cylinder tin, dog house fan shroud, dog house oil cooler, backing plate, rear tin, 2pc.rr.cool tins, alternator, welded and balanced cooling fan, fan hardware kit, chrome upper pulley, with black CE insert and CE nut, black CE aluminum lower pulley and nut, fan belt, aluminum oil filler neck, billet oil filter cap, billet fuel pump block off, alternator stand, strap, and  breast plate.
Pertronix billet distributor with electronic ignition, billet dist. clamp, pertronix plug wires, NGK spark plugs, cap, rotor, oil pressure switch.
Dual 48 Weber IDA carburetors 3hole, Custom under alternator linkage, velocity stack screens, and fuel hose.
Heavy duty aluminum raised roof engine case, full flowed, shuffle pinned center mains, added material behind ¾ cylinders, 8mm case savers.
84mm forged 8 dowel counter weighted crankshaft (std/std) Chevy journals.
Hardware kit complete-bolts, nuts, chromoly  head studs, high pressure oil relief valves.
Scat H-beam connecting rods 5.5, with ARP bolts, Chevy journals.
Camshaft and lifter set Web 86a/Web lifters
Web Steel Straight cut cam gear set.
Main, rod, and cam bearings.
Light weight forged 8 dowel flywheel, chromoly gland nut and washer.
Gasket kit with rear main seal.
Oil pump-Melling high volume, with full flow cover.
94mm forged pistons and liners Mahle, with Teflon buttons.
CB Wedge Port 44x37mm 94 bore with IDA Wedge Port big beef manifolds
9.5 compression
Cool tins
Aluminum  pushrod tubes.
Billet oil plate and deep sump kit.
Manton Chromoly  pushrods.
Scat 1.4 Ratio rocker arms
Aluminum bolt on valve covers
Stage 2 Kennedy pressure plate
Fully balanced
pris 60000dkr kan leveres i norge gratis men så skal den være solgt inden næste weekend da jeg har en ven der kommer ned fra norge og tar hjem igen den lørdag 25okt
for foto se her og video
http://vwvintagerides.blogspot.com/
http://vwnettet.dk/forum/topic/439561
« Siste redigering: oktober 24, 2008, 07:05:25 am av thomas lybbe » Loggført
« Svar #1 på: oktober 16, 2008, 10:06:27 am »
Dritlekker motor med 194 hk
glemte jeg å si lekker? hehe
* 100_1352(1).jpg (93.67 KB, 615x461 - vist 381 ganger.)
* 100_1352.jpg (93.67 KB, 615x461 - vist 303 ganger.)
T2-Vandal
Bosted: Nord-Fron
« Svar #2 på: oktober 16, 2008, 10:34:07 am »
Ja dette var ryddig og skjønt.. Kunne hatt den i stua Gliser
29 Chevrolet AC Phaeton
47 Farmall A
66 T1
70 T1 (German look)
78 Corvette sachs 380
77 T2 (Vandalbussen)
72 Eldorado cab
08 Alfa Romeo 159 Ti
thomas lybbe
« Svar #3 på: oktober 16, 2008, 11:32:38 am »
glemte at der er 1 års warrenty på Glad
thomas lybbe
« Svar #4 på: oktober 20, 2008, 08:27:15 am »
kan evt leveres til norge den 25okt
thomas lybbe
« Svar #5 på: oktober 23, 2008, 11:54:43 am »
ny hurtig pris 65000nkr incl fragt til norge den 25okt og med 1 års warrenty fra powerhouse usa (john the owner of the shop)
bygge pris 9000usd kurs 5,8 = 52200 + fragt fra usa og told afgift ca 25.000dkr oveni og vi snakker om DKR ikke NKR
så prisen på 65000nkr leveret den 25okt er billigt
thomas lybbe
« Svar #6 på: oktober 24, 2008, 07:05:48 am »
solgt til martin Glad)))
