juli 23, 2026, 20:55:18 pm *
Skrevet av Emne: kompressor for sandblasting is needed  (Lest 3115 ganger)
neriosius
Bosted: aalesund
« på: mars 15, 2009, 17:27:56 pm »
i am looking for 1 fase kompressor to be powerfull enough for sandblasting
« Svar #1 på: mars 15, 2009, 19:14:04 pm »
1fas og sandblåsing går som regel ikke hånd i hånd
neriosius
Bosted: aalesund
« Svar #2 på: mars 15, 2009, 19:31:49 pm »
it would be enough for me 1 phase, 50 liter tank and 4 HP , there is no outlet for 3 phase so i have no other option
T2-Vandal
Bosted: Nord-Fron
« Svar #3 på: mars 15, 2009, 19:40:41 pm »
Check it out..
http://www.finn.no/finn/bap/object?finnkode=16693029
29 Chevrolet AC Phaeton
47 Farmall A
66 T1
70 T1 (German look)
78 Corvette sachs 380
77 T2 (Vandalbussen)
72 Eldorado cab
08 Alfa Romeo 159 Ti
MariusR
Bosted: Ålesund
« Svar #4 på: mars 15, 2009, 19:46:35 pm »
Are you fixing the black splittbus who Bjørn T had???
neriosius
Bosted: aalesund
« Svar #5 på: mars 15, 2009, 19:48:52 pm »
its 1,3 hp and 0.9 kw, its too weak for sandblasting, i have myself such one so one minute sanding and 5 min smoking Glad
neriosius
Bosted: aalesund
« Svar #6 på: mars 15, 2009, 19:50:07 pm »
yes the same buss  Gliser
MariusR
Bosted: Ålesund
« Svar #7 på: mars 15, 2009, 19:50:56 pm »
Ok where are you working on it?
neriosius
Bosted: aalesund
« Svar #8 på: mars 15, 2009, 19:53:31 pm »
in aalesund,engine and chasi is now on the way to norway already fixed
MariusR
Bosted: Ålesund
« Svar #9 på: mars 15, 2009, 21:09:00 pm »
Where did you send it for welding?
neriosius
Bosted: aalesund
« Svar #10 på: mars 15, 2009, 21:16:05 pm »
all welding work i do myself with a friend mechanic, but engine with gear case i took to lithuania to a friend who took it apart changed all parts and now its working propertly. so all body work will be finished as soon as i will get drivers doors
« Svar #11 på: mars 16, 2009, 07:39:41 am »
normally the biggest Compressor you can get with 1phase is a 3hk. buy 2 of these. This will give you around 600liters/min. and if you need more, buy 1 more Blunker
neriosius
Bosted: aalesund
« Svar #12 på: mars 16, 2009, 18:50:58 pm »
is it possible to rebuilt compressor from 3 phase to 1 phase? i found a cheap one 6 kw plus 300 l tank
« Svar #13 på: mars 16, 2009, 22:44:10 pm »
It's possible but it will not work, normal fuses is maximum 16amp, and that is not enough for 6kw.
