august 05, 2026, 20:24:21 pm *
Skrevet av Emne: MSD 7AL-2 Med 2 step, coil og piller selges  (Lest 1784 ganger)
« på: januar 28, 2008, 01:21:56 am »
For den som trenger seriøs gnist!
Dette er storebroren til 6AL boksene.. Men kan på ingen måte forveksles.
Boksen er brukt til dragracing. Og har da såklart ikke gått mange timene.
Selges montert via gummioppheng på aluplate. Good to go...
Prisen er 2700,-[/u]  hentet på Jessheim.
Kan sende mot porto.
Erik. Tlf 91610027
Specs klippet fra Jegs.com sine sider:
7AL-2 IGNITION
The 7AL-2 is the choice of professional racers from six second Pro Stocks to Monster trucks. The CD circuits deliver full energy sparks to the plug throughout 14,000 rpm ensuring that even the most exotic fuel combinations are thoroughly ignited. A special coil coupler increases spark duration and protects the Ignition in the event of coil failure. MSD's accurate Soft Touch Rev Control is built into the 7AL-2 so our Module Selectors and other rpm controls can easily be connected. To survive the demands of heavy duty racing applications, the circuit boards receive a heavy duty coating of Humi-Seal compound. This substance seals the circuits for resistance to vibration and moisture. Heavy duty vibration mounts are also supplied. The 7AL-2 is a proven winner on tracks around the world.
OPERATING SPECIFICATIONS
Operating Voltage: +12-18 VDC Negative Ground
Current Requirements: 6 Amps-6,000 RPM 12 Amps-12,000 RPM
RPM Range: 14,000 RPM with 14.4 Volts
Spark Duration: 20° Crankshaft Rotation
Energy Output Max: 105-115 mJ Per Spark
Weight and Size: 4.75 lbs, 8''Lx3.75''Wx5.75''H
Voltage Output Max: Primary: 480 Volts Secondary: 50,000 Volt
* 121-7226.jpg (16.93 KB, 250x240 - vist 245 ganger.)
« Siste redigering: januar 28, 2008, 22:15:58 pm av Jee » Loggført
« Svar #1 på: januar 28, 2008, 22:15:36 pm »
Solgt!!!  Øyerulling
