juli 09, 2026, 00:22:37 am *
Skrevet av Emne: Kort eller lang  (Lest 1333 ganger)
nk
Bosted: Hønefoss
« på: august 11, 2010, 18:47:59 pm »
Kort eller lang til skråstilt pumpe " for vekselstrøm "
* VW 091.jpg (150.83 KB. 1024x768 - vist 115 ganger.)
tlf: 40843606
« Svar #1 på: august 11, 2010, 19:03:03 pm »
http://www.vwparts.net/mm5/merchant.mvc?Screen=PROD&Product_Code=113127307&Store_Code=VWP&search=fuel+pump+rod&offset=0&filter_cat=&PowerSearch_Begin_Only=&sort=&range_low=&range_high=
"This Is The Push Rod For Your Fuel Pump On 1200-1600Cc Engines With Generators. This Is The Longer Of The 2 Different Rods. For Use With The Generator Fuel Pump."
Altså: lang = likestrøm, kort = vekselstrøm?
nk
Bosted: Hønefoss
« Svar #2 på: august 11, 2010, 20:11:59 pm »
Takk.
tlf: 40843606
