august 06, 2026, 10:03:42 am *
Skrevet av Emne: JPM 1915 motor selges eller byttes i skuddsikker girkasse  (Lest 1985 ganger)
perings
« på: september 01, 2010, 08:03:50 am »
Pga endring i planer selges en meget sprek 1915 bygd av JPM. Selges uten tenning,  tørrsump er bygd om til vanlig oljepumpe.Spesifikasjoner fra tidligere annonse. Kjøper betaler frakt. Kan byttes i girkasse m drivaksler bygd for dragracing. Kassa bør være med spole og relativt "bulletproof"
Per
1915 cc built by JPM in spring 2007.
> > > > > > Has run few street kilometers and 15 laps on Knutstorp racetrack.
> > > > > > Leakdown 3% cold.
> > > > > > Ticks like a swiss watch.
> > > > > > Valve lash has barely moved since it was set and delivered by JPM. Says quite a lot about the stability of this engine.
> > > > > > DMS counterweighted crank
> > > > > > Stock renovated rods.
> > > > > > 94 Mahle w teflon buttons
> > > > > > New CB 044 40X35,5 and ported by JPM. Intake mildly welded and matched.
> > > > > > Shuffle pins on block.
> > > > > > Lifter gallery drilled for extra lube.
> > > > > > Cr moly studs.
> > > > > > New lifters and FK 87 cam
> > > > > > 1:1,4 rockers
> > > > > > JPM Oteva 75 springs Cr moly retainers
> > > > > > GB 160 000 psi pushrods
> > > > > > New valve covers
> > > > > > New PR tubes
> > > > > > Deep sump
> > > > > > German steel flywheel
> > > > > > Kennedy stage II with Daikin disc
> > > > > > 009 (not the one in picture)
> > > > > > DLRA 48
> > > > > > 1 5/8" merged exhaust
> > > > > > Compression ratio: 10,5:1
> > > > > > All oil plugs removed, drill and tap for new threaded
> > > > > > Super detail balance by JPM.
> > > > > > More details done, too much to list. Just stuff JPM does because he simply will not let out second quality stuff.
> > > > > > Estimated 150-160 hp but JPM believes with some dyno time (engine was run as delivered) 170 at 6500+ rpm is possible
perings
« Svar #1 på: september 01, 2010, 08:13:28 am »
Glemte pris :40000kr Glad
Per
perings
« Svar #2 på: september 02, 2010, 10:07:29 am »
perings
« Svar #3 på: september 03, 2010, 11:53:15 am »
Solgt
