august 04, 2026, 19:14:42 pm *
Skrevet av Emne: S:nye justerbar offset springplates splitbus fra wagenwest  (Lest 750 ganger)
thomas lybbe
« på: august 11, 2011, 15:07:44 pm »
S:nye justerbar offset springplates splitbus fra wagenwest.. passer sådanne at man bruger en 1968 type 1 gearkasse bolt on med alt og ikke mere
1955-67 adjustable off set spring plates enable you to lower the rear of your pre 1967 Volkswagen bus 3.5 inches by swapping the reduction gear transmission with a long axle type one or type three swing axle transmissions.
All of our plates come with custom shock mounts attached.
What you need to do the job
#1 A set of off set spring plates.
#2 a 68 bug swing axle transmission or a pre 67 type 3 transmission.
#3 brakes if you use the 68 bug transmission you can machine a set of pre 63 bus drums to fit over the bug brakes or if you use a type 3 you can buy wide five drums.
#4 A pair of emergency brake cable spacers.
You will also need to take the bus nose cone off of the bus trans and use it on the bug or type 3 transmission. By far the easiest way to lower the back of your bus. We also have several different types of brand spanking new made in the USA spring plates from off set to dog legged straight axle and IRS as well as adjustable
pris 3500dkr kan leveres til scc
* adjustoff_.jpg (68.29 KB, 600x358 - vist 138 ganger.)
« Siste redigering: august 11, 2011, 15:13:50 pm av thomas lybbe » Loggført
thomas lybbe
« Svar #1 på: august 15, 2011, 21:01:44 pm »
3000DKR
