mai 21, 2026, 08:26:40 am *
Skrevet av Emne: UPDATED: Big time sale!!! Clear-out time! Make me an offer, I need to sell!!!  (Lest 3100 ganger)
Lee.C
You either "Get It" or you don't.....
« på: november 29, 2013, 04:09:15 am »
Well here we go I thought it was about time I put ALL my items in ONE thread.....
Here is EVERYTHING I have for sale..... All items are located at the following address in NORWAY!
- Haakons Gate 9
- 1607 FREDRIKSTAD
- NORWAY
Just in case you want to collect......
- x1 "doghouse" Oilcooler Mount I removed this from a early 70's 1300cc motor - You can buy these repro (approx £40!!!) BUT this is an ORIGINAL VOLKSWAGEN item for half the price!!!
Ideal if your building a bigger motor Glad
http://www.thesamba.com/vw/classifieds/detail.php?id=1565793
- 200kr SHIPPED ANYWHERE!
(these parts are approx £40 new!)
- x1 Early 50's (split) metal 6v battery cover, early 50's 6volt battery cover from a split window bug - I have had this laying around for ages and I am sure someone can use it for their restoration, This is an ORIGINAL VW item from a 1951 Split window "crotch cooler" car,
http://www.thesamba.com/vw/classifieds/detail.php?id=1565799
- 150kr SHIPPED anywhere,
- x1 30hp VENTURI ring & themostat linkage, I removed this from an old 30hp motor that had been sitting in our workshop for years,
This is 100% original VW item and perfect for a PROPER restoration
http://www.thesamba.com/vw/classifieds/detail.php?id=1565803
- 300kr SHIPPED ANYWHERE!
. x1 PAIR of Early 60's Beetle Backing Plates, these are in VERY good condition with all the adjuster tabs intact,
These are original VW items removed from an early 60's car,
http://www.thesamba.com/vw/classifieds/detail.php?id=1565806
- 400kr SHIPPED ANYWHERE!
- x1 PAIR of early 60's linkpin spindles in very good condition! all the threads are ok and there is even the little rubber gromet for the speedo cable,
http://www.thesamba.com/vw/classifieds/detail.php?id=1565808
- x1 Original 6v Dynamo pulley
This is an original 60's item in VERY good condition and ready to use
- 100kr SHIPPED ANYWHERE!
- x1 PAIR of original vw Dual Port Manifold End Pieces  INC rubber boots & clips!
These are an original pair of LATE dual port end pieces from a late model 1600 engine, They still have the original rubber boots and vw clips
- x1 original Late Bay indicator lense HELLA/German!
an original hella indicator lense for the LEFT FRONT of a late bay window bus
- x1 Early bay (walkthru) Spare wheel cover (with VW logo!)
This is an original spare wheel cover from a 1968 "walkthru" bus it sits in the left rear corner and cover the spare tire, I good condition and ideal for a restoration
- x1 NoS/Boxed! VDO Oil Pressure Sensor TWIN TERMINAL (for the oil light!)
This is an original 1970 GERMAN VDO oil pressure sensor for after market VDO gauges but it has TWO terminals so it also works the Oil Light on the dash/speedo, Its still in it original 1970's box!
- 250kr SHIPPED ANYWHERE!
- 90% of a NOS front quarter panel.... for a PRE67 beetle......
Basiclly I brought a complete nos panel a few weeks ago and then CUT the piece I needed from it...... There are now 2 (two) fender bolts/threads missing from the rear most part.....I am sure someone can put the rest of this NOS panel to good use, Its PERFECT for making proper fitting repair patches.....
What you see is what you get.....
http://www.thesamba.com/vw/classifieds/detail.php?id=1522485
800kr  SHIPPED ANYWHERE!!!
- original 6volt Dynamo stands - mid 60's .....
These are the INDUSTRIAL type with the mounting area  on the front (3 m6 bolts)
- 350kr EACH SHIPPED ANYWHERE!
- 1200/40hp Cylinder head tinware - mid 60's ...
I have for sale x1 pair (two) 1200/40hp Cylinder head tins from a mid 60's INDUSTRIAL firepump engine
These are original VOLKSWAGEN parts in very good condition, They will work with all the other tinware/exhaust parts I have for sale,
- 200 SHIPPED ANYWHERE!
http://www.thesamba.com/vw/classifieds/detail.php?id=1475422
- 30hp Cylinder head tinware - Early 50's.......I have for sale x1 pair (two) 30hp Cylinder head tins - from a early 50's 30hp oval engine,
These are ORIGINAL VOLKSWAGEN parts in very good condition for their age,
http://www.thesamba.com/vw/classifieds/detail.php?id=1475423
- Cool "industrial" Fan Housing - 1960's ..... I have for sale a COOL "Industrial" Fan Housing that I removed from a 60's Firepump engine I brought a while back, This is the early 1200cc style ie "non fresh air" and the oil cooler inside,
I was going to use it on my 65 but I decided I wanted better heating Wink
As you can see it has ALL the original vw stickers and a COOL "Mesh" fan guard/cover which is all ORIGINAL FACTORY FITTED!!!
Being from a firepump means it has NO thermostat flaps etc,
- 400kr SHIPPED ANYWHERE!!!
http://www.thesamba.com/vw/classifieds/detail.php?id=1457899
- X3 Bosch Logo'd Coil Clamps - Original VW items ....I have for sale x3 BOSCH logo'd coil clamps - These are original VW FACTORY items form the mid 60's
These are a cool finishing touch to any old skool motor
- 100kr EACH SHIPPED ANYWHERE!
- SW Ammeter gauge - 6volt - Rare! .... I have for sale x1 Original 60's SW Ammeter (brass casing) & mounting plate
This is a 6volt gauge, its ideal for an early bug..... I was going to use it in the 65 but I've changed my mind and I have WAAAAAAAAAY too many parts just sitting around gathering dust and I am sure someone can put it to good use
What you see is what you get..... 400kr SHIPPED ANYWHERE!!!
http://www.thesamba.com/vw/classifieds/detail.php?id=1522484
- SW oil pressure gauge - 6volt type ....I have for sale x1 Original 60's SW Oil Pressure gauge (brass casing) & mounting plate
This is a 6volt gauge but it does need a sender unit, its ideal for an early bug..... I was going to use it in the 65 but I've changed my mind and I have WAAAAAAAAAY too many parts just sitting around gathering dust and I am sure someone can put it to good use,
http://www.thesamba.com/vw/classifieds/detail.php?id=1522483
- X2 (pair) NOS/boxed Cal Custom Air Filters .....I have for sale x2 (pair) NoS/BOXED Cal Custom Air filters from the 1970!
These are original unopened 1970 custom parts - Perfect for that vintage parts display
As you can see they are in near perfect condition and I am only asking 400kr SHIPPED ANYWHERE!
http://www.thesamba.com/vw/classifieds/detail.php?id=1475053
- old "Home made" wooden dash panels ...... I have for sale x2 Original 60's "Home made" wooden dash panels..... These actually came with the SW gauges I have for sale so if you want to do a "Deal" on everything (gauges/panels etc) I am sure I can do you a good price
I have tried to show the sizes of the holes etc if you want to use them for your own gauges
250kr SHIPPED ANYWHERE!!!
http://www.thesamba.com/vw/classifieds/detail.php?id=1522551
- x1 ORIGINAL/NEW VW Michelin XZX 185 SR14 "Early Bay" Spare tire..... BRAND NEW (old!) VW Michelin XZX 185 SR14 Spare tire for sale.....I have just removed this from the original spare wheel in my 68, This tire has never been used/driven and still has the little bobbles/tags on it..... This is ideal for a "Concours Restoration" as this is a PROPER VW fitment item, I am asking 400kr COLLECTED!
- x1 early solid bug wheel... Wide 5/ 5x205...... Dated 2/64.... .....
x1 original vw "Solid" style early bug wheel, ideal if you are missing a spare wheel!
- 200kr COLLECTED!!
- NOS/Boxed GRANT Steering wheel boss late bay window buses.... 72up
it come with ALL the original Nuts & Bolts and even the instructions.... These are the older (70/80's) PROPER GRANT bosses and NOT the lower quality things you can buy today!
- 350kr SHIPPED ANYWHERE!!!
- x1 13/15/1600 SINGLE PORT manifold, From a late 60's 1500 motor,
Original condition & ready to use,
http://www.thesamba.com/vw/classifieds/detail.php?id=1565796
- x1 PAIR Buggy "lowback" fibreglass seats & covers, BRAND NEW!
(see pictures!)
- 1500kr each or 2750kr PAIR
- x2 BATTERY BOXES
Inc lid/cover, BRAND NEW!
- 500kr SHIPPED ANYWHERE!!!
- x2 VDO Jet Cockpit 52mm gauges & extra bezels......
- x1 Fuel gauge
- x1 Ammeter gauge (30amps)
- x2 spare 52mm Jet Cockpit bezels
- 400kr EACH SHIPPED ANYWHERE!!!
- x1 Gasser Bonnet (pre67 style) , BRAND NEW!
No Hinge panel/pin style mounting needed OR I can supply a hinge panel that can be "bonded in" at an extra cost of course,
- 2500kr COLLECTED
- x1 PAIR (x2) Pre 67 Style FLARED Gasser front fenders/wings,
BRAND NEW!, NO headlamp bowls,
- 2000kr COLLECTED
- x1 6v Dynamo backing plate,
Original VW item,
- 200kr SHIPPED
Right I think thats it..... I do have various small interior parts/nuts/bolts/fittings etc etc so drop me a PM if there is something small you need..... I look forward to hearing from you all soon.....
Paypal: cookseylee89@yahoo.co.uk
Email: monki772003@yahoo.co.uk
Tel: +4740067168
Please check out my other ads for some cool/useful/interesting stuff
http://www.thesamba.com/vw/classifieds/search.php?username=monki77
« Siste redigering: januar 10, 2014, 01:53:33 am av Monkiboy » Loggført
Lee.C
« Svar #1 på: november 29, 2013, 15:16:37 pm »
A few items sold but still loads here.....
Make me an offer I can not refuse  Blunker Glad
Lee.C
« Svar #2 på: november 30, 2013, 05:14:24 am »
Lee.C
« Svar #3 på: desember 01, 2013, 01:46:08 am »
Lee.C
« Svar #4 på: desember 02, 2013, 05:33:56 am »
Lee.C
« Svar #5 på: desember 05, 2013, 07:01:46 am »
Anyone want anything today  Hæ Glad
Lee.C
« Svar #6 på: desember 08, 2013, 22:40:09 pm »
open to offers  Glad
Lee.C
« Svar #7 på: desember 10, 2013, 23:45:55 pm »
If your interested in anything drop me a PM......
Its christmas sale time  Blunker Glad
Lee.C
« Svar #8 på: desember 12, 2013, 12:27:51 pm »
Lee.C
« Svar #9 på: desember 18, 2013, 14:04:15 pm »
I need this stuff gone......
Open to offers
Lee.C
« Svar #10 på: desember 23, 2013, 00:51:22 am »
Open to offers
Lee.C
« Svar #11 på: desember 30, 2013, 00:09:57 am »
Open to offers
Lee.C
« Svar #12 på: januar 10, 2014, 01:52:50 am »
Open to ANY offers on EVERYTHING!!!!!!!!!!!!!!!
Lee.C
« Svar #13 på: januar 14, 2014, 20:21:45 pm »
Nordtveit
Bosted: Ålesund
« Svar #14 på: januar 14, 2014, 23:11:13 pm »
150,- inkl shipping??
facebook.com/nordtveitsgarage
instagram: Nordtveitsgarge
1956 Oval---solgt---
1964 Panelbuss "Gulbuss'n"
1958 T1, Ratlook "Rat'n"
Lee.C
« Svar #15 på: januar 15, 2014, 02:27:38 am »
PM sent  Blunker Glad
