august 04, 2026, 06:29:11 am
Ram 5135 Iron disc (black magic) 200mm, ny!
Emne: Ram 5135 Iron disc (black magic) 200mm, ny! (Lest 1224 ganger)
juli 13, 2015, 17:30:12 pm »
Pga feilsending (jeg skulle ha 228mm) selger jeg en ny 200mm clutch disk fra Ram i "5135 materiale".
2000,- + frakt
(68.06 KB, 800x600 - vist 128 ganger.)
Sv: Ram 5135 Iron disc (black magic) 200mm, ny!
juli 14, 2015, 08:43:35 am »
Litt mer info om Ram:
http://www.ramclutches.com/dragrace.html
"The RAM single iron clutch assembly is an economical choice for racers from Stock eliminator to fast street. The 5135 compound sintered iron disc allows the clutch to work, or 'slip' as needed in order to get the vehicle to launch smoothly without overpowering the tires. "
juli 14, 2015, 20:28:32 pm »
Med dagens dollarkurs kan jeg ikke annet en å kjøpe denne. Frakta til SCC står du for selv. OK?
juli 14, 2015, 21:50:33 pm »
Sitat fra: BeetleBug på juli 14, 2015, 20:28:32 pm
Det er ok. Vi kan ta betaling der også hvis det er greit for deg
