august 06, 2026, 00:07:58 am *
Skrevet av Emne: Ny 2332 ccm med 1 års warrenty Sælges  (Lest 9158 ganger)
thomas lybbe
« på: november 05, 2009, 19:25:39 pm »
info kommer senere
pris 65000nkr
bygget af powerhaus i usa..
ca 180hk++ og 230nm++ ved 3800omdr
komp 9.5
« Siste redigering: november 05, 2009, 19:29:13 pm av thomas lybbe » Loggført
thomas lybbe
« Svar #1 på: november 06, 2009, 18:28:34 pm »
A1 side winder exhaust system ceramic coated
Black dual port cylinder tin, dog house fan shroud, dog house oil cooler, backing plate, rear tin, 2pc.rr.cool tins, alternator, welded and balanced cooling fan, fan hardware kit, black upper pulley and nut, balck aluminum lower pulley and nut, fan belt, aluminum oil filler neck, alternator stand, strap, and breast plate.
Distributor with compufire ignition inside, clamp, plugs, wires, cap, rotor, oil pressure switch, and Bosch coil.
48ida´s paintet black and match portet manifolds paintet black
Heavy duty aluminum raised roof engine case, full flowed, shuffle pinned center mains, added material behind ¾ cylinders, 8mm or 10mm case savers.
84mm forged 8 dowel counter weighted crankshaft (std/std) Chevy journals.
Hardware kit complete-bolts, nuts, chromoly head studs, high pressure oil relief valves.
H-beam 5.5 connecting rods, with ARP bolts, Chevy journals.
Camshaft FK8 , and scat ligth weigth racing lifters
Straight cut cam gear set.
 Light weight forged 8 dowel flywheel, chromoly gland nut and washer.
Gasket kit with rear main seal.
Oil pump-Melling high volume, with full flow cover
94mm forged pistons and liners Mahle, with Teflon buttons.
steve tims stage 2 super street strip heads 62cc and 42/37 valve with match portet manifolds.
Cool tins
Stainless steel pushrod tubes.
Billet oil plate and deep sump kit.
Chromoly pushrods.
Scat 1.4 rockers shafts with stock adjuster, lash caps.
Aluminum or Stock style valve covers.
Fully balanced
thomas lybbe
« Svar #2 på: november 10, 2009, 00:36:43 am »
evt seriøse bud modtages
larsra
Bosted: moss
It`s a Bug`s Life.....
« Svar #3 på: november 11, 2009, 11:57:03 am »
HVOR MYE FORLANGER DU? Hæ
66`s boble
« Svar #4 på: november 11, 2009, 12:13:49 pm »
info kommer senere
pris 65000nkr
komp 9.5
Race-buggy
Bosted: sørlandet
boblekameratene
« Svar #5 på: november 11, 2009, 12:24:43 pm »
« Siste redigering: juli 29, 2010, 11:20:08 am av Race-buggy » Loggført
Race-buggy.
black bullet-59 boble
« Svar #6 på: november 11, 2009, 12:30:45 pm »
info kommer senere
pris 65000nkr
komp 9.5
http://vwnettet.dk/topic/160235   Blunker
Står jo ikke noe mer der enn det som står her?
Race-buggy
Bosted: sørlandet
boblekameratene
« Svar #7 på: november 11, 2009, 12:51:01 pm »
« Siste redigering: juli 29, 2010, 11:20:35 am av Race-buggy » Loggført
Race-buggy.
« Svar #8 på: november 11, 2009, 12:52:33 pm »
info kommer senere
pris 65000nkr
komp 9.5
se engang til og så ser du forskjellen
Hvis du tenker på prisforskjellen, så er det kanskje du som må se en gang til før du insinuerer noe som ikke stemmer i en salgstråd.
65k norske (jeg antar nkr som han oppgir bak prisen sin = norske kroner) er cira 56k DKK....
« Siste redigering: november 11, 2009, 12:59:15 pm av Trond Dahl » Loggført
Race-buggy
Bosted: sørlandet
boblekameratene
« Svar #9 på: november 11, 2009, 12:59:04 pm »
« Siste redigering: juli 29, 2010, 11:21:16 am av Race-buggy » Loggført
Race-buggy.
« Svar #10 på: november 11, 2009, 13:00:36 pm »
Eller du kan bare smile og innrømme at du var litt for raskt på triggeren? :-)
Vi stopper forsøplinga her..
Beklager Thomas
Race-buggy
Bosted: sørlandet
boblekameratene
« Svar #11 på: november 11, 2009, 13:04:48 pm »
« Siste redigering: juli 29, 2010, 11:19:41 am av Race-buggy » Loggført
Race-buggy.
thomas lybbe
« Svar #12 på: november 11, 2009, 13:36:49 pm »
istedet for at skrive frem og tilbage så kom med bud . Det er en seriøst motor, der er et par stk. i norge der har købe nogen af mine andre motorer og har været fuld tilfreds
« Svar #13 på: november 11, 2009, 13:44:08 pm »
Thomas : Har du bilde?  Blunker
thomas lybbe
« Svar #14 på: november 11, 2009, 13:59:14 pm »
kommer og lidt har sendt til trond...som ligger dem ud for mig
« Svar #15 på: november 11, 2009, 15:03:56 pm »
bilde
* 2332.jpg (90.3 KB, 1024x768 - vist 837 ganger.)
thomas lybbe
« Svar #16 på: november 12, 2009, 13:46:16 pm »
tak trond... ps jeg har flere fotos af opbygningen hvis nogen er interesseret i at se...
men kom med seriøs bud og motoren kan blive din....
ps de steve tims toppe der sidder på motoren er lige så vilde som cb wegde portet....  den eneste fordel er at steve tims er håndbygget toppe og ikke alt de kina junk
« Svar #17 på: november 12, 2009, 13:49:08 pm »
Sitter med mail og koser meg, kjør på Thomas!  Er det video også?
« Siste redigering: november 12, 2009, 13:52:19 pm av surfer56 » Loggført
thomas lybbe
« Svar #18 på: november 16, 2009, 12:38:07 pm »
motoren er stadigvæk til salg da køber ikke havde nogen penge Trist(((
kom med seriøse bud HVIS i har penge og ikke snak
« Svar #19 på: november 16, 2009, 13:14:31 pm »
Det gikk på prio, ikke peng Blunker
thomas lybbe
« Svar #20 på: november 16, 2009, 14:04:28 pm »
jeg ved det.... jeg er heller ikke sur,, jeg vil bare kun ha folk kontakter mig hvis de er klar til at købe Glad)))
mvh thomas
« Svar #21 på: november 16, 2009, 14:08:40 pm »
Prøvde å hjelpe så godt jeg kunne Blunker
thomas lybbe
« Svar #22 på: november 17, 2009, 14:16:51 pm »
i  no Glad
thomas lybbe
« Svar #23 på: november 22, 2009, 11:39:46 am »
ingen seriøse bud?Hæ?
thomas lybbe
« Svar #24 på: november 24, 2009, 14:51:30 pm »
ny video med startup and fin tuning
thomas lybbe
« Svar #25 på: november 27, 2009, 20:47:26 pm »
jule pris 55000nkr
thomas lybbe
« Svar #26 på: desember 02, 2009, 11:11:17 am »
ingen interesseret
Frode
Bosted: Ås
« Svar #27 på: desember 02, 2009, 16:59:36 pm »
Jo.....men har ikke penger :-)
« Svar #28 på: desember 02, 2009, 17:02:01 pm »
Er det 55K levert i Norge eller henta i DK?
thomas lybbe
« Svar #29 på: desember 02, 2009, 17:26:50 pm »
incl levering til norge
