august 06, 2026, 12:52:09 pm
72 bus headlights
Emne: 72 bus headlights (Lest 1876 ganger)
Dave
72 bus headlights
mai 30, 2012, 21:01:32 pm »
Hi
I have imported my English early bay camper and am trying to get its first Norwegian EU Control.
It is failing as the headlights produce the incorrect light pattern.
I have replaced the glass, reflector and bulb with Norwegian parts but still no luck.
Does anyone have any good ideas about what could be wrong or know where I could get a decent pair of used units???
Any help appreciated!
Thanks in advance
Dave
Dragset'n
Bosted: Sunndalsøra
tlf 91544358
Sv: 72 bus headlights
mai 31, 2012, 17:20:03 pm »
have you tried adjusting the direction of the lights? Your lights are adjusten for rhd?
www.volkswest.no
Dave
mai 31, 2012, 20:17:19 pm »
Thanks for the reply. We tried that but it didn't have any effect on the shape of the beam. The guy testing it seemed to think it could be the way the bulb fits in the reflector. He thought the bulb should be rotated so the single pin on the back of the bulb was at the top. This isn't possible as there is only one position the bulb can sit in the reflector. This means the single pin sits at about 3 O'clock. Have tried 3 different bulbs but still no luck. Any ideas?
Unneberg Bil
Forhandler
SVARER PÅ MAIL. IKKE PM!!!!!
mai 31, 2012, 22:53:21 pm »
did you replace your old reflecktors whit T1 units ? they are simelar but rotated 90 *
åpent man-fre 0900-1600
IKKE PM !!
Tlf 33330606
deler@unneberg-bil.no
Dave
juni 01, 2012, 07:52:03 am »
That is a possible explanation! I purchased these from you guys with ref 43863. The part number on the invoice is 312-941.151/B/GEN although I am not sure if this is what I received as the label is no longer on the reflector. Could you check that this is the right part number for a bus though? Is there any other way of seeing if it is a bus or beetle reflector?
Dave
juni 01, 2012, 08:04:28 am »
It seems like this reflector is sold for both bus and beetle. How does this work? As you say the light unit is rotated to fit the bus. It didn't actually seem like the beam was out by 90 degrees though. A bit more like 45. I thought at first the bulb had been manufatured incorrectly but have tried various different bulbs now and they are all the same... Any ideas??
