august 05, 2026, 13:43:21 pm *
Skrevet av Emne: Type 4 motor, spacer til vippestell  (Lest 2471 ganger)
sveinongen
« på: april 17, 2017, 14:48:06 pm »
Hvor får man tak i spacere og shims til orginalt vippestell? skal bruke 1700 type 4 vippearmer sammen med CB swivelfeet er det god kombo?
14 Lexus IS300h
01 Audi A6 2.4 Quattro
75 Dobbelkabiner  2.0L CJ motor
08 Ford Connect
93 Golf 1.6l
93 Golf 3 VR6
06 Lexus IS220d
96 Golf 3 2.0l
sveinongen
« Svar #1 på: april 19, 2017, 20:26:17 pm »
Vis andre trenger så fikk jeg tak i her
http://type4store.com/products/valvetrain/rocker-spacer-kit.html
Solid Rocker Assembly Setup
With the variance found in heads, rocker shafts, rocker spacers and rocker arms it will be necessary to “fit” each rocker spacer and assembly during the assembly of the engine.
To do this you will assemble each rocker arrangement complete with rocker arms, spacers, hardened spacer shims and shafts and slide it onto position on the cylinder head. You must ensure that the bevel on the bottom of the rocker shaft faces down, toward the head or damage to the shaft/studs could occur.
Tighten the shaft into place and torque the fasteners to 15 lb/ft. Then check the side play in the shaft. These should be tight or may be almost seized in place as we have made these spacers to fit very tight to reduce valve train noise.
Using a belt sander or file remove an even amount of material across the aluminum spacer, refitting it till no more than .006 of horizontal  lash is found in the assembly with the unit torqued into place.
14 Lexus IS300h
08 Ford Connect
93 Golf 1.6l
93 Golf 3 VR6
06 Lexus IS220d
96 Golf 3 2.0l
Race-buggy
Bosted: sørlandet
boblekameratene
« Svar #2 på: april 19, 2017, 22:44:13 pm »
GetBackOnTrack/Jakob spring selger også. jeg har kjøpt til alle mine motorer av han.
https://da-dk.facebook.com/GBOT.dk/
http://gbot.dk/
Race-buggy.
black bullet-59 boble
