« Svar #1410 på: februar 10, 2016, 08:58:46 am » |
Og så var girkasse endelig bestilt.. Det ble KCR. Kevin hadde en grunnpakke med en haug med options, jeg tok absolutt alle: Noe jeg bør endre på før han går i gang?
The gearbox will have all of the best options.
Weddle ring & pinion Weddle torsional input shaft Weddle 1st - 4th gears New German bearings Limited slip diff New sliders Bus into Bug gear carrier New reverse gear New nose cone and shift selector R.E.M. polish all internals Chromoly pinion retainer Steel sleeve pinion bearing bore in main case New synchonizers KCR race prep
Also shipping 930 cv joints (German), chromoly axles, boots and clamps
« Siste redigering: februar 10, 2016, 09:06:44 am av Formula Vee »
« Svar #1411 på: februar 10, 2016, 09:19:47 am » |
Kevin kan bygge kasser men jeg håper virkelig at han har skjerpet leveringstiden sin! Betal kun depositum slik at du har ett pressmiddel når forsommeren banker på døra og du står der uten kasse.
Mvh BB
« Svar #1412 på: februar 10, 2016, 09:21:33 am » |
Hello again Jan,
Thank you for your order. I am confirming that you are ordering the High performance Bus IRS gearbox that we talked about in our previous email.
Build time will be dependent on how long Weddle takes to R.E.M. polish the internals. It typically takes them about 7 to 10 days. Once I get the parts back from them, it will take about one week to assemble the gearbox. I can not give you an exact date because I have to send the internals to Weddle. However, they do have all of the gears in stock. I have a steel sleeved case in stock. The Peloquin diff is available and everything else is readily available. So there should not be any delays.
« Svar #1413 på: februar 10, 2016, 09:22:28 am » |
Dette blir kanon Jan Olav!
Street car 10.67/206kmt@Kjula 2014 Race car 9.49/236kmt@SCC 2017  "It seems that perfection is reached not when there is nothing left to add, but when there is nothing left to take away"
« Svar #1414 på: februar 10, 2016, 09:28:52 am » |
Det er ihvertfall den optimale løsningen for meg totalt sett ut i fra fra jeg ønsker å bygge om på bilen og bruk.
Her er gearene som ble valgt:
Weddle 4.13 r/p med 2.90 1. =72.74 kmt. Med 0.89 på 4. =236.57 kmt. Dette med 26" og 7K. 2. og 3. blir 1.86 og 1.22
Diff:
« Svar #1415 på: februar 10, 2016, 09:44:38 am » |
Jeg setter 100,- kroner og en bamseklem på at vi feirer nasjonaldagen vår før du har kassen din hjemme.  -BB-
« Svar #1416 på: februar 10, 2016, 09:46:13 am » |
Jeg setter 100,- kroner og en bamseklem på at vi feirer nasjonaldagen vår før du har kassen din hjemme.  -BB- Hvis du har så veldig lyst på en klem Kalle, bare gi beskjed. Du får en gratis
« Svar #1417 på: februar 10, 2016, 09:47:25 am » |
Jeg setter 100,- kroner og en bamseklem på at vi feirer nasjonaldagen vår før du har kassen din hjemme.  -BB- Hvis du har så veldig lyst på en klem Kalle, bare gi beskjed. Du får en gratis  Tusen takk! The heat is on.
« Svar #1418 på: februar 10, 2016, 09:48:08 am » |
« Svar #1419 på: februar 10, 2016, 10:17:25 am » |
Jeg sjekket i litt gamle eposter. Sist gang jeg kjøpte kasse fra KCR brukte han 21 dager fra vi var enige om detaljer til kassen ble sendt avgårde. I mine øyne er dette mer enn godt nok når det gjelder å få bygget en girkasse.
Gangen før derimot tok det lenger tid, cirka 3 mnd i praksis, men dette var delvis på grunn av han ventet på å få den guessetted, som tok en måned. Dernest brukte han 20 dager på å bygge kassen for så å ta jule/nyttårsfri hvor på det ble litt samtaler rundt shipping osv. I tillegg klarte DB Schenker å rote vekk kassen på vei til Norge, men det var jo ikke hans feil.
Så i praksis ser det ut til at han fint klarer å bygge kassen på under en måned, men at andre faktorer kan spille inn. Derfor er det så viktig å bestille kassebygging i god tid før man trenger den.
« Svar #1420 på: februar 10, 2016, 10:29:52 am » |
Nice!!! Ble det dyrt?.....
« Svar #1421 på: februar 10, 2016, 10:43:03 am » |
Nice!!! Ble det dyrt?.....  Ja
« Svar #1422 på: februar 10, 2016, 10:44:53 am » |
Vwfreaks (Kai) kjøpte nylig, veldig fornøyd med service og leveringstid.
« Svar #1423 på: februar 10, 2016, 10:44:58 am » |
Nice!!! Ble det dyrt?.....  Ja Og så var girkasse endelig bestilt.. Det ble KCR. Kevin hadde en grunnpakke med en haug med options, jeg tok absolutt alle:
« Svar #1424 på: februar 10, 2016, 10:45:31 am » |
« Svar #1425 på: februar 10, 2016, 11:01:44 am » |
Jaja, go big or go home! Du glemmer kostnadene det sekundet du fyrer opp den motoren  Alt etter det er ren bonus. Og med dagens Porsche priser så er jo dette en veldig rimelig hobby faktisk. Det er hvert fall mitt argument til kona
« Svar #1426 på: februar 10, 2016, 11:05:37 am » |
Fortalte i går kveld til henne jeg deler postkasse med, at jeg endelig hadde handlet girkasse. "Så bra!" -Hvor mye kostet den da?" "Den kostet under 10.000,-" "-Åja." Trenger vel ikke akkurat å spesifisere valuta heller..
pWolf
« Svar #1427 på: februar 10, 2016, 11:45:50 am » |
Fortalte i går kveld til henne jeg deler postkasse med, at jeg endelig hadde handlet girkasse. "Så bra!" -Hvor mye kostet den da?" "Den kostet under 10.000,-" "-Åja." Trenger vel ikke akkurat å spesifisere valuta heller..  Jeg bruker akkurat samme teknikk
Reiel
« Svar #1428 på: februar 10, 2016, 12:18:31 pm » |
Fortalte i går kveld til henne jeg deler postkasse med, at jeg endelig hadde handlet girkasse. "Så bra!" -Hvor mye kostet den da?" "Den kostet under 10.000,-" "-Åja." Trenger vel ikke akkurat å spesifisere valuta heller..  Jeg bruker akkurat samme teknikk  Og alle håper at sine respective koner IKKE er innpå her så altfor ofte
Mvh Reiel
« Svar #1429 på: februar 10, 2016, 12:21:44 pm » |
Dette ser jo veldig bra ut:
« Svar #1430 på: februar 10, 2016, 13:07:27 pm » |
Genialt!  Jeg er nok litt ærligere og svarer enkelt: Mine penger!
« Svar #1431 på: februar 10, 2016, 13:17:57 pm » |
Fortalte i går kveld til henne jeg deler postkasse med, at jeg endelig hadde handlet girkasse. "Så bra!" -Hvor mye kostet den da?" "Den kostet under 10.000,-" "-Åja." Trenger vel ikke akkurat å spesifisere valuta heller..  Jeg bruker akkurat samme teknikk  Og alle håper at sine respective koner IKKE er innpå her så altfor ofte  Hadde ikke turt å skrive det under "Snikk snakk" for å si det sånn.. Sikkert litt tryggere i blant det mer tekniske innholdet.. Nei dette ble for mansjåvinistisk..
Hans
« Svar #1432 på: februar 10, 2016, 16:08:53 pm » |
hvor mye koster en slik porsche kasse i disse dager ?
o 1958/64 T1 Ragtop o 1957 T1 o 1989 T3
« Svar #1433 på: februar 10, 2016, 16:42:25 pm » |
Har aldri spurt noen om pris, men en G50 pleier å ligge på rundt NOK 100.000 om du klarer å finne en. Har sett en på Ebay og en på Thesamba.com (Om ikke det var den samme) Men en sånn ombygging blir for mye for meg, dette er tross alt en gategodkjent bil for 158hk. Vanskelig å få godkjent G50 i bilen nå.
vwfreaks
Bosted: Naglestad
« Svar #1434 på: februar 10, 2016, 16:53:15 pm » |
Blir det lettere å få godkjent 500hk  :-)
T1 1969 Stepside pickup T1 1951 "Voltswagen" T1 1970 Baja, MONGOL RALLY 2020 Godkjent BT 1952Tempo Matador
"Cut weld and drive"
« Svar #1435 på: februar 10, 2016, 16:57:26 pm » |
Blir det lettere å få godkjent 500hk  :-) Skal ikke prøve å godkjenne 500hk. Bilen blir avregistrert når stor motor blir bremset. 1915 turbo står komplett i hjørnet og passer rett i, så den går tilbake og skiltene på igjen.
Jesper1201
« Svar #1436 på: februar 10, 2016, 17:20:38 pm » |
Blir det lettere å få godkjent 500hk  :-) Skal ikke prøve å godkjenne 500hk. Bilen blir avregistrert når stor motor blir bremset. 1915 turbo står komplett i hjørnet og passer rett i, så den går tilbake og skiltene på igjen. Av- og påregistrert hjemme i garasjen?
« Svar #1437 på: februar 10, 2016, 17:45:53 pm » |
kan jo bli bra det der.  har du fått eller bedt om noen dokumentasjon på fremgangsmåten han bruker på oppsett av R/P? ved nytt pinion lager+ R/P må jo dette settes opp skikkelig. Grunnen til att jeg spør er att min KCR 091 kasse med Weddle R/P var ikke satt opp rikitg som medførte til skadet/utslitt R/P etter kort tid. SKiftegaffle 3/4 gir var også justert feil som hadde ført til stor slitasje grunnen til jeg nevnte Rancho/mike herbert på fæce er att han gjør det skikkelig med farge. det er jo en tidkrevende prosess. inn og ut flere ganger, shimse og farge.
« Svar #1439 på: februar 10, 2016, 22:33:54 pm » |
SCC 14,257
