mai 06, 2026, 02:58:41 am *
Sider: 1 ... 46 47 [48] 49 50 ... 68
Skrevet av Emne: Turboroadster -Snekkermesteren selger bilen med 500+hk boblemotor.  (Lest 933293 ganger)
« Svar #1410 på: februar 10, 2016, 08:58:46 am »
Og så var girkasse endelig bestilt.. Det ble KCR. Kevin hadde en grunnpakke med en haug med options, jeg tok absolutt alle:
Noe jeg bør endre på før han går i gang?
The gearbox will have all of the best options.
Weddle ring & pinion                                                      Weddle torsional input shaft
Weddle 1st - 4th gears                                                   New German bearings
Limited slip diff        New sliders
Bus into Bug gear carrier                                               New reverse gear
New nose cone and shift selector                                  R.E.M. polish all internals
Chromoly pinion retainer                                                Steel sleeve pinion bearing bore in main case
New synchonizers                                                         KCR race prep
Also shipping 930 cv joints (German), chromoly axles, boots and clamps
* 11082630_889316647792327_2143364113729925941_n.jpg (38.2 KB, 640x480 - vist 501 ganger.)
« Siste redigering: februar 10, 2016, 09:06:44 am av Formula Vee » Loggført
« Svar #1411 på: februar 10, 2016, 09:19:47 am »
Kevin kan bygge kasser men jeg håper virkelig at han har skjerpet leveringstiden sin! Betal kun depositum slik at du har ett pressmiddel når forsommeren banker på døra og du står der uten kasse.
« Svar #1412 på: februar 10, 2016, 09:21:33 am »
Hello again Jan,
Thank you for your order. I am confirming that you are ordering the High performance Bus IRS gearbox that we talked about in our previous email.
Build time will be dependent on how long Weddle takes to R.E.M. polish the internals.  It typically takes them about 7 to 10 days. Once I get the parts back from them, it will take about one week to assemble the gearbox.  I can not give you an exact date because I have to send the internals to Weddle.  However, they do have all of the gears in stock.  I have a steel sleeved case in stock. The Peloquin diff is available and everything else is readily available. So there should not be any delays.
« Svar #1413 på: februar 10, 2016, 09:22:28 am »
Dette blir kanon Jan Olav!
« Svar #1414 på: februar 10, 2016, 09:28:52 am »
Det er ihvertfall den optimale løsningen for meg totalt sett ut i fra fra jeg ønsker å bygge om på bilen og bruk.
Her er gearene som ble valgt:
Weddle 4.13 r/p med 2.90 1.  =72.74 kmt. Med 0.89 på 4. =236.57 kmt.  Dette med 26" og 7K.
2. og 3. blir 1.86 og 1.22
Diff:
* 091.jpg (39.03 KB, 800x600 - vist 408 ganger.)
« Siste redigering: februar 10, 2016, 09:32:49 am av Formula Vee » Loggført
« Svar #1415 på: februar 10, 2016, 09:44:38 am »
Jeg setter 100,- kroner og en bamseklem på at vi feirer nasjonaldagen vår før du har kassen din hjemme.
« Svar #1416 på: februar 10, 2016, 09:46:13 am »
Hvis du har så veldig lyst på en klem Kalle, bare gi beskjed. Du får en gratis  Rekker tunge
« Svar #1417 på: februar 10, 2016, 09:47:25 am »
Tusen takk! The heat is on.
« Svar #1418 på: februar 10, 2016, 09:48:08 am »
« Svar #1419 på: februar 10, 2016, 10:17:25 am »
Jeg sjekket i litt gamle eposter.
Sist gang jeg kjøpte kasse fra KCR brukte han 21 dager fra vi var enige om detaljer til kassen ble sendt avgårde. I mine øyne er dette mer enn godt nok når det gjelder å få bygget en girkasse.
Gangen før derimot tok det lenger tid, cirka 3 mnd i praksis, men dette var delvis på grunn av han ventet på å få den guessetted, som tok en måned. Dernest brukte han 20 dager på å bygge kassen for så å ta jule/nyttårsfri hvor på det ble litt samtaler rundt shipping osv. I tillegg klarte DB Schenker å rote vekk kassen på vei til Norge, men det var jo ikke hans feil.
Så i praksis ser det ut til at han fint klarer å bygge kassen på under en måned, men at andre faktorer kan spille inn. Derfor er det så viktig å bestille kassebygging i god tid før man trenger den.
« Svar #1420 på: februar 10, 2016, 10:29:52 am »
Nice!!!
Ble det dyrt?..... Øyerulling
« Svar #1421 på: februar 10, 2016, 10:43:03 am »
Nice!!!
Ja
« Svar #1422 på: februar 10, 2016, 10:44:53 am »
Vwfreaks (Kai) kjøpte nylig, veldig fornøyd med service og leveringstid.
« Svar #1423 på: februar 10, 2016, 10:44:58 am »
Osteaktig
« Svar #1424 på: februar 10, 2016, 10:45:31 am »
 Gliser Kult
« Svar #1425 på: februar 10, 2016, 11:01:44 am »
Jaja, go big or go home!
Du glemmer kostnadene det sekundet du fyrer opp den motoren  Gliser
Alt etter det er ren bonus.
Og med dagens Porsche priser så er jo dette en veldig rimelig hobby faktisk. Det er hvert fall mitt argument til kona  Kult
« Svar #1426 på: februar 10, 2016, 11:05:37 am »
Fortalte i går kveld til henne jeg deler postkasse med, at jeg endelig hadde handlet girkasse. "Så bra!" -Hvor mye kostet den da?"
"Den kostet under 10.000,-"
"-Åja."
Trenger vel ikke akkurat å spesifisere valuta heller.. Hemmelig
pWolf
« Svar #1427 på: februar 10, 2016, 11:45:50 am »
"-Åja."
Jeg bruker akkurat samme teknikk  Gliser
1965 t1
Reiel
« Svar #1428 på: februar 10, 2016, 12:18:31 pm »
"-Åja."
Og alle håper at sine respective koner IKKE er innpå her så altfor ofte  Gliser Gliser Kult
Reiel
« Svar #1429 på: februar 10, 2016, 12:21:44 pm »
Dette ser jo veldig bra ut:
* gir.jpg (59.12 KB, 635x596 - vist 486 ganger.)
« Svar #1430 på: februar 10, 2016, 13:07:27 pm »
Genialt! Gliser
Jeg er nok litt ærligere og svarer enkelt: Mine penger! Osteaktig
« Svar #1431 på: februar 10, 2016, 13:17:57 pm »
"-Åja."
Hadde ikke turt å skrive det under "Snikk snakk" for å si det sånn.. Sikkert litt tryggere i blant det mer tekniske innholdet.. Nei dette ble for mansjåvinistisk..
Hans
« Svar #1432 på: februar 10, 2016, 16:08:53 pm »
hvor mye koster en slik porsche kasse i disse dager ?
o 1958/64 T1 Ragtop
o 1957 T1
o 1989 T3
« Svar #1433 på: februar 10, 2016, 16:42:25 pm »
Har aldri spurt noen om pris, men en G50 pleier å ligge på rundt NOK 100.000 om du klarer å finne en. Har sett en på Ebay og en på Thesamba.com (Om ikke det var den samme)
Men en sånn ombygging blir for mye for meg, dette er tross alt en gategodkjent bil for 158hk. Vanskelig å få godkjent G50 i bilen nå.
vwfreaks
Bosted: Naglestad
« Svar #1434 på: februar 10, 2016, 16:53:15 pm »
Blir det lettere å få godkjent 500hk Hæ   :-)
T1   1969 Stepside pickup
T1   1951 "Voltswagen"
       1952Tempo Matador
"Cut weld and drive"
« Svar #1435 på: februar 10, 2016, 16:57:26 pm »
Skal ikke prøve å godkjenne 500hk. Bilen blir avregistrert når stor motor blir bremset. 1915 turbo står komplett i hjørnet og passer rett i, så den går tilbake og skiltene på igjen.
Jesper1201
« Svar #1436 på: februar 10, 2016, 17:20:38 pm »
Av- og påregistrert hjemme i garasjen?  Blunker
« Svar #1437 på: februar 10, 2016, 17:45:53 pm »
kan jo bli bra det der. Glad
har du fått eller bedt om noen dokumentasjon på fremgangsmåten han bruker på oppsett av R/P?
ved nytt pinion lager+ R/P må jo dette settes opp skikkelig.
Grunnen til att jeg spør er att min KCR 091 kasse med Weddle R/P var ikke satt opp rikitg som medførte til skadet/utslitt R/P etter kort tid.
SKiftegaffle 3/4 gir var også justert feil som hadde ført til stor slitasje
grunnen til jeg nevnte Rancho/mike herbert på fæce er att han gjør det skikkelig med farge. det er jo en tidkrevende prosess.
inn og ut flere ganger, shimse og farge.
Jærva
Bosted: Østlandet.
« Svar #1438 på: februar 10, 2016, 20:51:49 pm »
100000 er vel å ta i litt da .....
Her er en som skal være 100% i orden og med garanti til drøye ca. 53 lapper ...
http://www.ebay.com/itm/Porsche-911-964-C2-Getriebe-G50-03-5-Gang-mit-Sperdifferential-9503011023R-/231747206083?fits=Make%3APorsche&hash=item35f535bbc3:g:UDkAAOSw~bFWQHMY
« Siste redigering: februar 10, 2016, 22:52:31 pm av Jærva » Loggført
« Svar #1439 på: februar 10, 2016, 22:33:54 pm »
"-Åja."
Osteaktig Osteaktig Osteaktig
